Truck disabled by some sort of electronic or software issue
marc_hanna
Marc
Nova Scotia
'23 Lightning Lariat ER; '25 Tesla Model 3; '16 Porsche Macan S; '87 MB 560SL
Since last Wednesday the 8th, my truck has had a strange issue that the dealer has been unable to fix. So far, the problem seems to be triggered by preconditioning the cabin through the Fordpass app. Basically, the truck is completely immobilized. Accessories will come on, but the truck cannot be shifted out of park. In order to get the truck into neutral, for towing purposes, you cannot use the instructions in the manual, but rather you have to press in both the brake and the accelerator with the accessories on and then pull it into neutral and press the temporary neutral button.
The first time it happened was after a day of driving, and the 12v battery simultaneously failed. We are not sure if these are related or coincidental. There was a stop vehicle immediately alert and a PWS alert. The Start button will not go solid when pressed, it will only flash.
Each time it was “fixed”, three times now, the technician was able to drive the truck and everything seemed fine. The common event before each occurrence, was preconditioning the cabin, which failed, according to the app.
Fixes so far include: replacement of 12v battery, which was done next day, and major software update of all systems which took 2 full days.
Whammy Bar
Get a loaner. Keep doing it. Count 30 days. Contact buyback team.
Did they use a high capacity 12v power supply when loading all the updates, they might have stressed the replacement 12v battery as well!!!!!!!!!!!!!!!!!!!!!!
marc_hanna
Marc
Nova Scotia
marc_hanna
Marc
Nova Scotia
I have no idea.
marc_hanna
Marc
Nova Scotia
The exterior power supply is important from other histories
Interesting, do you by any chance have a few more details that I can pass along? It’s hard to convince the service guys that some other guys on a forum said “such and such” is the problem.
flux capacitor
2023 F-150 Lightning
That is very interesting I had something kind of like that. This may not be related, but I will tell my story.
I went out to my truck to get the actual mileage for my charge log I keep. Because after the karaoke update the Ford Pass app was not keeping up with the mileage anymore. The truck is in my garage so it is never locked. I went without my phone or a key not thinking and I opened the door thinking it would just light up like it had in the past, but it did not the dash screen was blank so I hit the button and the dash and big screen flashed then went out with a message to enter backup code because no key was detected. Unfortunately I do not remember what that code is I have it in my phone. I got my key and phone but now the dash still blank, but the big screen came on, but the shifter was locked. I tried everything shut it off waited and tried again. It finally let me put it in gear, but dash still blank. I had an errand to run and figured I could still use it without the dash, but I needed to get my wallet so shut it off got my wallet back it the truck and dash still blank now big screen is also blank and I cannot even turn it on or put it in gear. I am totally locked out of driving it. I had to take my ICE vehicle. When I got back about 45min later I tried again and everything was back to normal. I can only guess that I triggered some kind of theft prevention that locked me out for a while, but it sure scared me thinking this truck essentially left me stranded even though I had a key plus phone as a key.
marc_hanna
Marc
Nova Scotia
Well, so far, according to the service department, they have had two calls into Ford Engineering to resolve the issue.
Whammy Bar
In Canada, I think you might need to use a power supply that is 1.4 times stronger due to the conversion.
Joking aside, the cold will also impact that battery performance. So they'd be wise to go beyond the minimum spec's being discussed. You essentially have to run the whole trucks systems via off-board power.
marc_hanna
Marc
Nova Scotia
I got a call from Ford Canada customer service yesterday. They are following the repair work and acting as a liaison. Basically, they are stumped. The dealer is working with Ford Engineering and running a bunch of tests. No ETA because after one full week, they have yet to even diagnose the problem, let alone figure out a repair plan.
I asked the Ford rep what sort of things they were testing, and he read off some notes to me. Not super meaningful, but it was regarding the 12v battery management system.
marc_hanna
Marc
Nova Scotia
Update: I called the dealer to get an update because I hadn't heard anything for a couple days. They still don't have a solution, and the EV tech that was working on it yesterday is off today. They said that there is a regional specialist that they hope to see in the next couple of days. So, what I inferred from that is that we're going to be looking at another week at least.
The truck is inside the bay and is not operational. They don't have a charging station inside, so they asked me to bring by my Level 1 station so they can charge it.
The Weatherman
Dean
South Central KY
? that doesn’t leave a warm and fuzzy feeling.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Sounds like they should order a Ford Mobile Charger and have the needed tool….?‍♂
