truck starts charging even when time set.
Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost
And I can’t set a new location because I only charge at one. Should I delete and restart the process?
Ford F-150 Lightning truck starts charging even when time set. IMG_5362
I'm confused!!!!
Ford F-150 Lightning truck starts charging even when time set. 1737578937225-1
Ford F-150 Lightning truck starts charging even when time set. 1737578911491-0o
Otherwise, the GPS location of truck and your default / home / named location charging scheme aren't matching.
Delete & recreate it is a common solution, do it in the sync screen while unplugged.
You may need to drive around the block to orientate the GPS.
Plug in create fresh scheme.
During the new scheme creation accept the suggested GPS coordinates if that is what is identified.
While creating new scheme include time frames if that's your intention., also include a weekend time frame.
EDIT:
On second thought, I see your 85% limiter, so location is recognized, but you do not have a properly specified time constraint.
Pitbull2o08
Pitbull2o08
Ohio
Honestly I think my phone has a mind of its own. Or I’m going crazy.
Why does it say you're charging at 12:30 AM but it looks like it's sunny out? Is your clock wrong?
Actually I was hoping you just traded up to a new MY2025 Lightning, but seems you still drive a 2023
Hahhhh, I bet AM/PM flipped, a great reason to stay on military time, if it would stay set.......
Pitbull2o08
Pitbull2o08
Ohio
Settings are good but it still charges when plugged in.
Ford F-150 Lightning truck starts charging even when time set. IMG_5365
Is the trucks actual clock time set in error as @Pioneer74 suggested, AM set instead of PM?
I’ve heard of folks having issues when setting to exactly 12:00. You might try changing the start time to just after 12.
Pitbull2o08
Pitbull2o08
Ohio
I’ll double check the clock this morning.
The truck didn’t charge overnight. And I have zero control over it with the app. Can’t charge, turn on or even unlock
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Perhaps the one-time charge option somehow is turned on?
Pitbull2o08
Pitbull2o08
Ohio
Y’all were right. Clock was flipped.
I still can't initiate the charge or adjust percentage in the app. i'm in beta though
