Installing New Pro Power today
gbuydos
Central Iowa
F150 Lightening Flash '24
The electrical contractor is at my house right now installing the Pro Power Charger. Will I need to do anything tonight when I go home to charge? Is it all plug n play? Do I need to set up anything?
Thanks.
JvdMaat
W. Mass
Plug and Play. It'll charge any vehicle with CCS port.
Though good luck trying to get the app to talk to the Pro charger. I spent days on that and just gave up. YMMV, it sounds like some people were able to get it setup.
gbuydos
gbuydos
Central Iowa
Thanks. I didn't know if I had to set it up to WiFi or the App before I could charge.
Maineiac12
Iowa
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Don’t get your hopes up, treat it like a dumb charger and life will be fine. Use the dial inside to select one of various amp levels delivered.
Good Luck
Keep in mind that unless your 2024 Flash is a fleet vehicle, the max charging you will get is 48amps, not 80amps.
gbuydos
gbuydos
Central Iowa
So as i have been told, you don't have to hook it up to the network, it would function as a dumb charger. What is the benefit of hooking it up to the network?
Yes, it will work, and probably won't give you any issues at 48 amps, causing the connector heat to prematurely signal an overheat condition.
The FCSP has a factory software update to fix this issue, that you'll likely never experience, folks charging at 80 amps on a hot summer day were having this issue.
Collecting charging statistics from the FCSP is pretty useful IMHO, but if you're not concerned then getting past any set up troubles won't be worth your aggravation, honestly hope it goes well for you.
Prodigy
Neil
2024 Ford Lightning F150 Lariat
I just had my installed last week and at first it was super frustrating because it charged for like 10 minutes perfectly fine and then it went to an error and it was charging at a “reduced charge”. The way I solved this after talking to Ford a couple times was to turn off the breaker to the charger itself and wait 10-15 minutes. Flip the switch back on and it worked like a charm.
You probably got the software update which implemented with the power cycling.
JvdMaat
W. Mass
Is there a way to get the update without WiFi? (USB, serial, etc). I gave up on trying to get it connected. My main WiFi is too far away, but even when I took an old AP and put it right next to the charger, it would not connect (wouldn't show up in the router DHCP table).
gbuydos
gbuydos
Central Iowa
The charger worked flawlessly. First time I woke up to a fully charged vehicle. I did not hook to Wi-Fi, I may eventually try, but after it warms up in spring. LOL.
