Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost
i got 1.4. But i'm missing 2 TPMS values.
Jmendozanunez
Jorge
24 Ford lightning
What am I doing wrong to connect my mongoose to fdrs and forscan . Says unable to connect ...Installed drivers and I'm able to get fdrs to says connected shows battery volt but when I try to scan Vin says device not connected but when I enter vin manually i click connect bottom symbol says connected ?
Pitbull2o08
Ohio
Mike G
N. AL, USA
Did you install the VCI manager from the Ford site as well?
Jmendozanunez
Jorge
24 Ford lightning
Yes I did . After installed that one I got vcm device options...I also can see my driver's are installed shows vehicle pass through and shows mongoose....but just strange I cannot even get forscan to connect
Is this a known working Mongoose? I haven’t looked but I think the Mongoose driver includes some toolbox programs you could try.
Does the Mongoose blink green when you plug it into the OBD port?
Mike G
N. AL, USA
I'm not sure what to tell you, I've used my Mongoose with FORSCAN plenty of times, but I generally only use the OBDLink MX+ for that (different laptop).
Jmendozanunez
Jorge
24 Ford lightning
Yes blinks green then solid green. But no communication still
21st Century Truck
Martin
I seem to remember that the Mongoose firmware can be flashed with upgraded more current RAM software... might be worth a look at the manufacturer's website. Not that I've ever done it on the Mongoose... I have done it with other dongle equipment.
Good Luck!
Pitbull2o08
Ohio
This video and @mr.Magoo helped with with issues setting up
PJnc284
Garner, NC
Sure you ordered the Ford version of the Mongoose? Where are you located? Maybe someone near you has a working one you can try. The only thing I recall installing was the Opus IVS Driver and for FORScan I just selected the mongoose on the screen below
Ford F-150 Lightning ECU module programming guide using FDRS 1737738963780-7s
Mike G
N. AL, USA
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
I was just in there.
Alright, dumb question. Where did you create your account? Every link I've found either directs to motorcraft.com (which is giving an error when trying to login or create account) or I was directed to www2.helminc.com for license validation.
Which site credentials do I use to login with FDRS? Side note, neither work.
I feel like I just wasted $100 because the MotorCraft website is down.
Ford F-150 Lightning ECU module programming guide using FDRS MotorCraft
Ford F-150 Lightning ECU module programming guide using FDRS Screenshot 2025-02-01 185635
