In regards to this OTA:
Some people that already got this update will get it a second time. I thought this was an issue only affecting the Mach E's, but apparently not. The second version will not update the software, but instead correct the config that is preventing one or more of the BC 1.4 features from working on your truck. Notice in the screenshot below that this version states wifi IS REQUIRED. This is one of very few OTA's Ford has ever sent out that require wifi to install.
Ford F-150 Lightning Bluecruise 1.4 officially being sent out to F150 & Lightnings starting today (12/11/24)! 1740429202909-jy
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Wait, so the CSP for the sensor IPMA update was missing configuration data and there is another update for the IPMA that requires wifi to correct the issue?
The CSP version with FDRS of the IPMA update was always missing the config. The OTA version was supposed to write it, but failed to do for many, or failed to write all the config, or failed to write any of the config at all.
But yes, the config only version of the OTA requires wifi according to PTS. I'd be interested to hear if someone does get it without being connected to wifi.
mattskr
Matt
Austin, Texas
23 Lightning Platinum, 25 Armada, 26 Wrangler JLU
I just got the BC 1.4 OTA now, so Ford is sending these still. Really curious as to what it does as I had enabled BC1.4 last week via the configuration changes @rugedraw shared with me and it works flawlessly. Says it's a 6 minute inhibit install.
All it does is make the same config changes you made. It will take 1-2 minutes in real time.
jetfixr1
Anthony
Atlanta
So your saying there is another pending OTA update for us all to correct config data on the IPMA? Which until then BC 1.4 will not fully function as intended?
Correct. Only owners who have an issue will appreciate this. If you got the BC 1.4 update and lane change, in-lane repo and predictive speed are all working, then this will do nothing for you. If you did get the OTA and one or more of these are not working, then this will fix whatever is not working.
If you got the IPMA updated via the dealer with the CSP, this will enable the features.
jetfixr1
Anthony
Atlanta
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
Just got my bluecruise 1.4 update.. was probably about a week after getting th latest gateway module update so I was hoping for 1.4 to come through... need to get out on the highway tomorrow and check it out... :)
The Weatherman
Dean
South Central KY
MY23?
I would be curious if this latest round of 1.4 updates have the same release note that Sync updates are coming later. I.e., you don’t have the toggles for Lane Change Assist and In-Lane Repositioning (but the functionality is there).
KennyB123
Ken
Detroit, MI
I could be wrong, but that's not what's coming later. I was one of the early 1.4 OTA guys, and I have the toggles. What I don't have is the graphical updates in my instrument cluster. That is what the OTA notes said were coming in a later update.
Here are what the original notes said (post #11):
Ford F-150 Lightning Bluecruise 1.4 officially being sent out to F150 & Lightnings starting today (12/11/24)! IMG_0571
I also got the early update but I had enabled sliders with FORScan. That’s why I’m curious if this update has notes that said the same thing.
Also curious if the update release at the bottom is still IPMA-24.204.10.9
