One Pedal and Hold feature, truck rolls
  • Thread starter Deleted member 15277
  • Start date
  • Watchers 10
Guest
One-pedal and Hold enabled driver here - have been since I got the truck new. ~28K miles later, I notice that when I come to a full stop, the truck then proceeds to roll forward a few inches after I take my foot off the brake. It feels intentional - not like slop or play, feels more like the motors (re)engage for a split second to move the truck forward before (re)applying the brakes. Almost like a "lurch". Sort of in the vein of "unintended acceleration" but I won't go so far as to label it that so as to not be alarmist.
The is especially noticeable if I come to a somewhat expedited stoppage (hard stop).
It's the electrons in your battery pack sloshing around.
Guest
You know what - it could be! LOL
You somehow summarized the feeling EXACTLY. Like if you ever driven a tanker trunk(oil/water etc) - that same inertial feeling of the load sloshing forward after a stop.
It's for smoother stopping.
Turn the hold off and see what happens.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I turned off the hold to allow me to creep in the garage, it also made driving feel normal. I do not move once stopped using one-pedal. If I stop more rapidly using the brakes, the truck also doesn't move once stopped.
evowner
Frank
SW Ohio
Retired EE
Lately I have been getting the feeling that I am still moving after I have stopped. It is like the sensation you get when riding in the back of a vehicle looking towards the back after stopping. This only happens when using one pedal. I think my brain is playing tricks on me. :crackup:
USA EV
I have the same experience as G2.
You're speaking of a change in behavior, correct? Can you reproduce it 100%? Probably worth getting checked out.
Guest
Definitely change in behavior. Caught my attention when the car in front of me braked hard at a red light and I did the same. Let off the brake, and felt the truck move forward a few inches - as if it were in creep mode. Was able to repeat that a few times.
I read some of the suggestions above like checking the auto-hold settings etc, Possibly one of those got turned on or off, (there are only two! LOL) - so I'll have to do some experimenting in each mode.
The fun thing is that it is hard to tell a mechanical problem from a possible software -update related issue - I wish I could "CTRL-Z" and undo the last update to see if the behavior is the same. Sadly, sounds like a trip to the service center - my first for a strange issue like this, and glad I posted because that "sloshing" feeling describes it perfectly, and is something I can convey to the service team - way better than my explanation :) So thanks to everyone who posted.
VTbuckeye
Vermont
Hopefully the service team is very familiar with EVs to know what feels right and what is abnormal. I feel like this is the perfect opportunity to gaslight the EV driver. "This is how they all behave" be e careful that they don't use any Jedi mind tricks.... These aren't the droids you're looking for..Move along "
Guest
Yeah - LOL - I hear ya - I'll be mindful - I've got 28K racked up on this truck and over 200K on other EV's - I'll _START_ with that upfront as an offensive defense :)
Grumpy2
23 F150 Pro SR
It must be normal, I unintentionally tested your issue.
Using one pedal I approached a car stopped at a light, and I misjudged my speed slightly and just touched the brake pedal and received a 99% when I stopped. When the light changed, the car slowly moved and I released the brake but didn't touched the go pedal since he was still close. The truck advanced a few inches before the brakes reengaged.
It must be something like 3" ? but it was clearly a movement. Not a big deal, but I see where it would be a concern if I had stopped close to the other driver.
It must be normal.
Guest
It must be normal.
Well, that sounds like the behavior. Why do I suck at describing things lately? Anyway you nailed it.
Is it "Normal"? I don't think so.
Is it "New"? Yeah, this is something new in the past few months for sure - thought it might be cold/winter related, but did not have this behavior before the fall for sure.
VTHokies
Jason
‘26 Chevy Silverado EV Max Range
mines been doing something like this for as long as I remember, since it's slight movement really hasn't bothered me but I forget the exact scenario it does it in. I use one pedal driving and have the auto hold on. If you are that close to a vehicle where this makes a difference then you are way too close!
Ish
‘23 Lariat ER
Ditto that this is new behavior from 1PD over the last few months. I had to have mine towed with the parking brake stuck on and thought that might have damaged something to cause this but hearing these stories feels like an unintended consequence of some update.
Weird behavior, but normal. My truck does it too. No idea if it's new; I rarely use the brake pedal all the way to a stop.
