Lightning Tremor Build
Mcfly
Billy
Socal
23 Pro SR
Realtor
My truck has been thru a few different builds. It started out as a stock pro, then modded into a budget Lariat. Because of the standard battery pack I was hesitant to do an off road build but I finally caved in. I've always liked the way the Tremor Ice trucks look and thought Ford should build this trim. Who knows maybe they will, a test mule was seen driving around a few years ago. I got the inspiration from seeing a post on the Raptor skid plate. Shout out to @Electric Marine and @AZT9. From there I just started getting the parts together. As for efficency, its been better than expected. I'm at 1500 miles on this set up, averaging 2.1. But that has included some road trips with an IKamper over the bed and a dirtbike on a hitch carrier. On my daily commute I average 2.3, 32 miles round trip mixed freeway (65 mph) and city.
Parts
Raptor Skid plate used ebay, I used a similar method to @derelict and what @Electric Marine and @AZT9 did for trimming. Active aero removed and disabled using Forscan.
Tremor lower valance trim Pieces, ordered from the dealer, part numbers ML3Z-17626-DA and ML3Z-17626-AB. The tremor skid plate is narrower than the raptor so you will have to trim these a bit. They sit on either side of the skid plate, bolt up with the existing holes under the bumper.
OEM Bedside and tailgate tremor decals ebay, removing the adhesive left from the lightning badges was harder than expected.
Raptor running boards used offer up, these suprisingly mounted up to the mounting brackets no problem. I found a set missing the brackets for sale locally, I just unscrewed my running boards from the brackets. I installed a set of led lights under the rear fender to replace the lights that were on the stock boards.
Upfitter Switches, link to my install thread https://www.f150lightningforum.com/...fitter-aux-switches-how-to.25671/#post-492493
Seat Covers, ICE OEM takeoffs from ebay
Steering wheel, Ice oem take off from ebay
Center Armrest Cover, Ice oem take off ebay
Towhook covers, Steering wheel decal, Grill decal, etsy. I wanted to mimic the 2024 style Ice tremor grill. I found a seller on etsy to make it custom. The towhook covers and steering wheel decal were listed for sale.
2 inch front Leveling kit, Rough country, this combined with the 1.5 inch rear lowering kit gave the truck a .5 inch rake.
1.5 Inch Rear Lowering Kit, I used the ice McGaughy's shock mount lowering kit and Icon rear camber kit. Rough country also makes a rear shock lowering kit now. I'm glad I installed the rear camber kit. I was able to do a 4 wheel allignment after getting the wheels and tires.
Trex T200 Wheels, Forged Monoblock 6061-T6 Construction, rated for 2456 lbs each, weight around 28 lbs.
Nitto Recongrappler AT Tires, size 275/65/R20 (34), 116t load rating, weight 47 lbs.
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090326937
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090319593
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090551078
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090353498
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090447528
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090340256
Ford F-150 Lightning Lightning Tremor Build IMG_20250319_090531757
Ford F-150 Lightning Lightning Tremor Build IMG_20250313_150933010_HDR
Ford F-150 Lightning Lightning Tremor Build IMG_20251029_153910881
Ford F-150 Lightning Lightning Tremor Build IMG_20251029_153849953
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143038537
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143046164
Ford F-150 Lightning Lightning Tremor Build IMG_20251106_143043498
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Looks good...maybe instead of "Tremor" an alternative name for Lightning is "Thunder"....low hanging fruit...
That's awesome! Trade mark it or Ford should pay you for the idea.
vic7780
Victor
Quantico VA
F-150 Lighting - Atlas Blue, Max Tow, 511a Package
Citizen
I was just thinking about this today…awesome
execution. I might try a few of these myself.
Who on Etsy did the grill work?
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
That is a great looking truck! Well thought out and executed! FoMoCo should sponsor your truck thanks to your dedicated replication
Thank you! I was inspired by your thread on the skid and raptor mods. Your truck looks awesome.
digitaldad
ABQ
2023 Lariat ER MaxTow
A lift kit and lowering kit on same vehicle, kudos. Looks cool!
How much weight was in that 2nd pic (I missed it, if it was stated)?
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Thanks, after measuring I figured this was the best way to get the truck level without doing a higher lift in the front. The bed is empty in both pics. Some slingshots are parked near by, optical illuison.
digitaldad
ABQ
Oh, dang, you're right. I could have swown that the front was raised more due to the bed weight.
brtnstrns
Seattle
2024 Lightning Platinum; 2022 Polestar 2 LRDM
Nice! I've been trying to see if anyone has put the Raptor/Tremor side steps on a Lightning yet. I may do the same to mine.
Just FYI, your side steps are actually installed backwards. The tapered/logo end is supposed to be at the rear of the vehicle. Surprised they mount either direction actually...
Example:
Ford F-150 Lightning Lightning Tremor Build TEW1E88PFA45509%2Ff61b199b352278c03959504b22a706c9
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Example:
I was surprised they bolted up and used the same mounts. Lots up for sale on marketplace and offer up.
Good catch, I mounted them backwards so my kids have the larger platform in the back. I've heard of dealers mounting them backwards on Raptors by mistake so it's definitely a thing.
FloridaMan655321
1973 F100, 2024 Flash
This is actually pretty nice. I'm usually not a fan of things like this, but this was fairly tastefully done.
What did you use for the striping on the 'grill'?
Did you replace the steering wheel with a tremor one? Or was this some addon?
As someone else mentioned, steps are wrong, but I'm sure you'll fix those. Hopefully you didn't mod anything haha
Edit, ignore me, I wasn't reading and missed the grill and steering wheel thing, which is etsy.
