FordPass app on iPhone in error
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
My iPhone is showing that my 2024 Flash is "ON" on the home page under the truck's image.. It's been sitting for 3 days. I know that it isn't on. I don't think the truck would even stay on that long if I inadvertently didn't turn it off when I left, would it? Unless the app is referring to the pro-power being set to on while the truck is off. But I don't think I even left that on last time I used it; I assume it goes to a default setting after awhile. I received an OTA update about 10 days ago and there were some changes but I noticed the "vehicle is on" thing changed to showing it was off. But now it's doing it again. Anyone else notice this?
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
I’ve found the latest few builds to be rather buggy.
- The charge history seems to be complete fiction.
- My L2 charger and the app disagree on the charging power by about 800 watts.
- Sometimes the charging details in the Energy tab, disappears completely.
- Received a notification recently that my 90 day Blue Cruise subscription was activated (I have a 3 year sub)
- Received an alert that software was updated, that the truck already updated the week prior.
Then there are these beauties:
Ford F-150 Lightning FordPass app on iPhone in error trim.76638834-9CA4-48A1-AE12-1354EF8E7D27
Ford F-150 Lightning FordPass app on iPhone in error trim.0E7B5430-D88E-4AEA-9E59-D61187B2632E
Which update? (view the software update screen for the code below description)
A few others have reported vehicle status is inaccurate on Fordpass.
Literider150
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
Shows v5.14.0 I see some changes. I see the new tire pressure & washer fluid items. Under "vehicle" connected services: before, I was getting nothing but a spinning circle. Now it shows screen to activate Blue Oval network but when I tap on "activate" it goes to a screen that just spins. Also when I tap on "manage connected services" all I get is a spinning screen. I don't get a cell signal from a cell tower where I live. Perhaps I need to go out to were there is cell service rather than relying on my home Wifi.
Also on Vehicle screen it shows Blue Cruise and "add it". But on my 2024 Flash I am supposed to get it for 3 yrs and as far as I can tell, it's already working. Lane keep works and the icon in lower right of driver's screen shows it is active when I press cruise.
Also under "Vehicle", it should say parked but it still says "Vehicle is On".
Take a look at the trucks Sync software update screen, curious as to your most recent OTA which is likely the root cause.
Literider150
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
Looks like that number would be Sync4 24127 revision 1270
I don't think the modem is working. Whenever I select the connectivity services tab it just spins. I am connected with my iPhone to see my phone through blue tooth but it won't get a connection to my wifi. There is no cell tower signal out here. Thanks
Look here (15.5" screen)
NOTE: this update is going to MY 2022 Lightnings based on member observations, you should show something different for your 2024 Flash.
Ford F-150 Lightning FordPass app on iPhone in error 1742776791102-nr
Literider150
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
Gateway module: ECG: 24.2.5.7 Thanks for leading me through this FWIW. Yeah mine ended in 7 w/o the last "1"
That's great to see that your truck is relatively current with updates, not certain if the truck is the cause of the iOS ailments but always a great starting point to see if others are experiencing the same problem at the same updates level.
Maybe a 12v reboot of the truck might / or not help?
Literider150
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
I'm going to go out to a solid cell tower area and try a reload of the Fordpass app. It's almost like it's downloading partially, not completely which seems weird to me, but what do I know.
If it were a bigger problem I'd try it. There is such an area not that far from me. Or wait until I go down to the treasure valley for supplies.
Scorpio3d
SS/IBA car wash owner
If you are not near cell towers, then it may be the modem in the truck is not able to communicate with the mothership and thus your FordPass app???
Literider150
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
If I open the Ford pass app on my phone, on the first page where it shows Vehicle, scroll down and it says "connection services". When I press on that it goes to a screen and it just spins. Also on the Vehicle screen, it shows the Blue Cruise sign up thing in a large frame, and also the Blue Oval network activation frame. If I click on either of these I also get the circle of death screen.
i still haven't taken a trip down to Boise to see if the cell towers there would help me connect to my modem. I tried taking out the fuse to reset the modem, but I'm not convinced that is the problem. F-150 is showing me the correct mileage and other information. But I guess that could be coming from bluetooth???
