Full charge but below 131 KW of usable power
TomB985
Isanti, MN
2022 Lightning XLT ER
What you get from the OBD device or other scanner connected to the truck computer is what the truck says the battery SOC is based on whatever method the truck is using to estimate it.
So my advice it to just relax and enjoy not having to buy gasoline, and only get worried if the reported battery estimate falls into the battery warranty range.
Exactly this. Our trucks are much more accurate than the ancient float gauges used in the ICE trucks, but they're not perfect. Your PCM reports a number, but that's never going to be exact.
My truck has never shown over 130 kWh available, and that number rarely lines up with my charge/discharge numbers. It tends to read low at higher SOCs, and it's not to be trusted in the single-digits.
It's just a number, your battery is fine. Enjoy your new truck!
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
This is what I've typically been getting with my truck 23ER with Car Scanner. 122-127KwH at 100% SOC Display. Not sure how accurate it is though.
Mine started doing this after the last update…. So now it thinks 125 kWh is 100%. Hoping it gets better with the next one… Thanks @Ford Motor Company
Ford F-150 Lightning Full charge but below 131 KW of usable power 1728014348627-v1
jamelski
Sacramento
2024 Lariat
@Billybender32 definitely something wrong. I’d take it into the dealer and leave it there for three weeks for them to figure out what’s wrong with it.?
1) Make sure you measure at a battery temp of 77 degrees.
2) Look at the SOH field and see if it's 100%.
3) Makes sure you charge from 20% or less to 100%, several times, and let it sit at 100%, before measuring. Battery cells have to balance.
kstype
Kurt
Pennsylvania
Principle Systems Engineer
1 too have a 24 flash ER . But what obd app are you guys using as I want to buy 1 that displays all the info you're showing.
Is it Bluetooth to your phone. Is there anyway to show it on the 15" screen via the app? Or do we already have this feature and I haven't played with all the apps and settings?
Rick
The Veepak OBD adapter and the CarScanner app would allow you to display dashboards they have pre configured on the 15” screen, like this:
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_2485
The Apple App Store link for the SW is:
https://apps.apple.com/us/app/car-scanner-elm-obd2/id1259933623
the OBD dongle is:
Veepeak OBDCheck BLE Bluetooth... https://www.amazon.com/dp/B073XKQQQW?ref=ppx_pop_mob_ap_share
Hope this helps!
Grease Lightning
Johnathan
Albany, Oregon USA
Well was finally able to drain the battery and charge it back up and top balance it. As I was doing some of this while out of town, please ignore the 69 hours that it took as I was modulating my charger remotely to have it finish when I was home.
So drained the truck down to 10% dSOC that was showing 12 kWh in the tank.
Ford F-150 Lightning Full charge but below 131 KW of usable power img_6902-jpg
Started it at around 10 amps 240v to stretch it to when I was anticipating returning from an out of town trip.
My charger said it was providing power for 68:54 and provided 147.288 kWh.
Ford F-150 Lightning Full charge but below 131 KW of usable power img_6937-jpeg
My FordPass notes shows 69 hours and the truck received 131.6 kWh of power over that time.
Ford F-150 Lightning Full charge but below 131 KW of usable power img_6936-jpeg
From Car Scanner the dSOC is showing 100%, shows only 128.56 kWh in the battery @ 66 deg F.
Ford F-150 Lightning Full charge but below 131 KW of usable power img_6939-jpg
also looks like the module variation was cut in half.
Battery health is still showing 99.5% @ 17.5 month.
So wish it didn’t take as long to actually do it, but battery is closer to what I have seen in the past and “found” some of the previous lost kWh noted by me and others.
From Car Scanner the dSOC is showing 100% and shows only 128.56 kWh in the battery @ 66 deg F.
Do you think the relatively slow charge rate had any influence on this as well? Either balancing or total capacity readings?
I know all L2 is slow compared to what it can do but 10a is a trickle charge even in comparison to a 48a or 80a charge.
Anyone know what the BMS is rated for on balancing current?
Grease Lightning
Johnathan
Albany, Oregon USA
If there was an impact it would likely be a positive one. Most rechargeable batteries enjoy the trickle charge over the the faster chargers.
Once it hits 99% it is pretty mute as the balancing process I have seen in the previous just charging to 100% days has always slowed to an extremely slow rate as the software is cramming all those electrons into other places in the pack.
That was my thought as well but wondered your opinion on it.
I have seen the same thing on my truck when charging to 100%.
Grease Lightning
Johnathan
Albany, Oregon USA
Definitely something going on with the BMS and some bs. Trying to drive the battery down and what should have been around 93% usable battery is still showing at 100%. seems @Ford Motor Company has a needed software fix in the future. ?‍♂
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_6948
MountainAlive
Massachusetts, USA
I’m experiencing this today after charging to 100% for the first time in a long while. I let it sit on my level 1 charger for 25 hours (yes it took 25 hours) to go from 97% to 100%. Then I hopped in to check things out in car scanner. It’s showing I only have 97% State of Health and 120.48kwh until empty. Display SOC is 100%. Then I took a drive for about 15 mins and the dash still says 100% but now car scanner says it’s 116.04 to empty. I cold started the truck in 37 F temps when I left. So I’m not sure what’s going on but it seems like some weird BMS stuff.
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_2438
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_2440
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_2434
Ford F-150 Lightning Full charge but below 131 KW of usable power IMG_2441
I expect your low capacity reading is caused mostly by the low temp. Like every other battery these lose capacity when cold. That's not cold, but it is still quite a ways off the 70-some degrees used when calculating nominal capacity.
Draining it down very low, and back to 100%, a few times, is also needed
Pittsboro, NC
2023 Ford Lightning XLT, Tesla MYLR, Toyota Tundra
You mentioned that you are regularly changing up to 90%
I assume this is on a level 2 charger. Even so, on a level 2 they recommend charging to 80% and only going higher if you’re taking a long trip. If you’re concerned about battery life, you will get better results stopping at 80%.
That is exactly correct. If the battery is 37 degrees, you have a big hit to available energy. If the battery is 77 degrees, it's close to perfect.
@MountainAlive, set a departure point, and charge to 100%. When it's ready for departure, go read the energy. It will be around 60 degrees, and should read in the high 120s.
.It will be around 60 degrees, and should read in the high 120s.
As low as 126 for me, but then a few months later it was 131.7.
The interesting part was when it hit 131.7 it flat STOPPED reporting a higher energy capacity yet continued to absorb energy for a few hours as it went from 99% to 100%.
Of note, the 131kwh reading wasn't near 77 degrees either. I don't remember the temp but I think it was a bit over 60.
(The 131kwh WAS after they pulled my battery apart to replace the contactors. I monitored it since it was showing 345 miles of range. The process may have reset the BMS, explaining the strange readings)
