flyct
- First Name
- Jerry
- Sep 28, 2023
- South Florida
- 2024 Ford Lightning Platinum & 2ea-2026 Tesla Juniper Model Ys
- Occupation
- Blissfully Retired
We have a setup that is designed for a typical portable gas generator.Other than the Ford Charge Station Pro, what other equipment is required to enable the use of my 24 ER Lariat to power my home?
1- A 30 amp generator inlet connection
2- A generator interlock kit to prevent grid and truck from powering the panel at the same time
3- A 30 amp generator cable to connect the truck to the inlet connection.
Be aware that if the ground connection is not disabled from the truck to the inlet the truck will throw a ground fault. It’s debatable whether this is code compliant.
An electrician installed Transfer Switch that also switches neutral will work with the Lightning without any modification. Not all transfer switches switch neutrals.
