23 ER not charging {Fix post 66}
Scorpio3d
SS/IBA car wash owner
So, I’ve been holding off on posting this, because the engineer that is in charge of this region, apparently had a death in the family. But I think there is some progress now. My vehicle is showing that it is charged at 256% in FDRS. So that’s why it’s not charging at all, or that’s what they figured out so far.
Another battery expansion OTA????
Ted23Lightning
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
F150ROD
U.S. Navy Retired
Yeah there's is something more going on here. I took a little drive to test it out this morning, deleted all settings again as suggested by @TaxmanHog.
Got home and plugged in, this time it initiated charge to 90% as required
Ford F-150 Lightning 23 ER not charging {Fix post 66} IMG_4847 2
Then received a "Charge Complete":
Ford F-150 Lightning 23 ER not charging {Fix post 66} IMG_4859 2
Im going to have to explain this to the dealer as the equivalent of having a bad fuel gauge sensor lol
GoodSam
Good
occupying space
I am having the same issue as you are. It started with the truck stopping charge at 88% while Ford Pass and inside the truck said 100%. Unplugged and the true charge would appear. It has since gone down to 86% and is now just idling at "Starting Charger"
See the Ford quote at this thread, "...reduced-driving-range-projection-and-hv-battery-pack-soc-unable-to-reach-target-charge":
https://www.f150lightningforum.com/...pack-soc-unable-to-reach-target-charge.23075/
"...This may be due to an issue in one or more cells within the HV battery pack. To correct the condition, run the "BECM Battery Health" application using the latest software version of the Ford Diagnosis and Repair System (FDRS). If any cells are identified as exceeding state of charge and/or capacity thresholds, refer to the Workshop Manual (WSM), Section 414-03A High Voltage Battery, Mounting and Cables > Diagnosis and Testing > High Voltage Battery, Mounting and Cables - Electric > Pinpoint Test AP > Step AP4 and continue diagnosis. If all cells are within state of charge and capacity thresholds or DTCs are present in the BECM, refer to the WSM for normal diagnosis."
F150ROD
U.S. Navy Retired
Perfect, thank you. It's going into the dealer this morning.
Ted23Lightning
Ted23Lightning
Ted
Update:
Great news! Got my Lightning back & everything is back to normal. Service Advisor stated that it was a software issue. They updated multiple powertrain & battery modules to the latest software. Thanks again for the helpful y’all! ?
Updating mine, so yeah, one of my battery modules is toast. Dealer has ordered. Hopefully it arrives sooner than later.
I don't recall, is this your first bad module? How many miles? '22 right?
Yup 22, first one for module for me at 60k
This is what bothers me about what Ford isn't disclosing. They have to know by now with all the failures what our overall life expectancy will be and how often failures will continue to happen. Will we be able to keep these trucks for 10 to 15 years? After warranty you can't afford to replace a module every 2 to 3 years.
F150ROD
U.S. Navy Retired
Agreed.
GoodSam
Good
occupying space
Not on the Safety Recall 25S18 HV Battery electrode misalignment notification?
Sad to have both general cell failures and cell misalignments causing module replacements.
F150ROD
U.S. Navy Retired
No not part of the safety recall, apparently it's not just a module but a full battery array? Sorry to hijack your thread with my issues, but it seemed so similar that I did not want to start a new thread. Anyways, truck has been at the dealer for 3 weeks with no movement. SA says the one and only person is working on a harness and the lift necessary for this work is not available at the moment smh..
Ted23Lightning
Ted23Lightning
Ted
What are the issues with ur Lighting?
F150ROD
U.S. Navy Retired
Update: Still sitting in the same spot since May12th. SA keeps telling me the same thing, "wiring harness" "Lift in Use". I'm starting to think it's a bunch of BS and they don't want to waste their time on EV's.
Anyone know if a buyback can be initiated under the Powertrain Warranty?
