SYNC-25.2.1.6.5: Walk Away Lock Clean-up
jobofly79
Joe
2024 Ford Lightning Flash 312A
Ford F-150 Lightning SYNC-25.2.1.6.5: Walk Away Lock Clean-up 1747334915455-fa
MODERATOR NOTE
6/3/2025 Thread title adjusted to remove {EAP} flag.
Jesse-Infotainment
2024 F150 Lightning Platinum
Would you mind sending me your vin. You have a 24 that shipped with it so I would like to see the files for the update
Jesse-Infotainment
Thanks. This is actually an APIM update. Its the same as the 24 Mach E started getting.
I thought it would be a BCM update but this must be geared for the early trucks to add the WAL toggles.
awilli1010
SE Michigan
I got this about a week ago as part of the frunk update. I reported that it doesn’t work. I received and email explaining that a fix will be released later. Hopefully this is it! Eap.
Thread title updated to describe what it's about.....
BTW, are there any version or release numbers associated with this????????
In the Mach E, the OTA is called SYNC-25.2.1.6.5 and updates Sync to version 25095.
BennyTheBeaver
Ouch, that stinks. Try a 12v reset by pulling the 12v Negative at the LVB. That (hopefully) will refresh all your modules.
jobofly79
Joe
Just called the dealer. They said it’s a P0929 error and that it requires an update. Said it’s ok to drive until I get it there on Monday. I think I will try to reeet the 12v this evening when I get home.
F150ROD
U.S. Navy Retired
You have a great dealer!
