Ford Rear Splash Guards install on Lightning Flash
AlaskaFlash
James
Juneau, Alaska
2024 F150 Lightning Flash
Hi Folks: I ordered and just installed rear splash guards on my Lighting Flash. There were a number of problems with design, hole alignment, etc. Do not follow the instructions, only remove the plugs where the screws go in, not the ones where a new plug is supposed to go in. I finally got them installed, but I am not happy with the end results. These splash guards need to be redesigned to fit the new F150. I assume that the design flaw is apparent in both the Lightning and the ICE versions of the 2024 model
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0255
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0252
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0249
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0251
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0250
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0253
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash IMG_0254
astrand1
Alex
Studio truck driver
I wonder how much of any efficiency would be lost with these. ? I’m assuming not a lot but still I wonder.
AlaskaFlash
AlaskaFlash
James
Juneau, Alaska
"Currently out of stock...not sure when or if will be available". BTW, I ordered these using my Ford Reward points. The Ford website said that this was the exact fit for my Lightning... Yea, right...
I have the Lightning ones and they fit perfectly.
BSEE SPARKY
Derek
Southern Indiana
2023 Lightning Lariat ER, MAX TOW, Power Running Boards
When I ordered mine I called ford to confirm. They had find the part #. Because it was not as obvious as web site implies.
Oafboy182
Justin
2025 Lighting Flash
I have these sitting in my garage waiting to be installed when I find the time. Now I'm wondering if mine are the right ones. The website said they were for the lightning. I'm going to have to give them a look see.
Well I just checked and they say lightning so i guess I'm good.
I like the Lightning in blue. My wife use a paint pen to do this - https://amzn.to/4jgvv4o
Looks like it has to be redone 2 years later.
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash Mudflaps before
Ford F-150 Lightning Ford Rear Splash Guards install on Lightning Flash Mudflaps after
nate002
nate
‘24 Flash | Antimatter Blue | 9.6kW Pro Power
Love it! Wonder if you use a clear coat pen if it’d last a bit longer. May do this to mine as well!
markericha
Rich
2024 F-150 Lightning Lariat
I put them on my truck and don't really notice any difference at all. I've taken the same road trips and gotten similar and sometimes better range, depending on conditions.
So far the only things I've seen absolutely tank range are speed, temperature and wind. Wind is the one that seems to be trickiest to me, as it's just hard to plan for.
When I ordered got and installed mine - perfect fit on my 2023 Pro - I used a link that someone on the thread had provided and used the reward points I got from buying the truck.
The instruction sheets had "2022 F-150 Lightning" printed on them.
The part numbers are shown on the instruction illustrations I think (attached files).
Anyway can get them (ones that fit the Lightning) on Amazon for $40 minus a 5% coupon just now, if you are unhappy with the ones you put on:
https://www.amazon.com/F150-Weather-Guards-Splash-Without/dp/B0CGDNGCJ2?th=1
BTW, the Ford ones I put on do the job pretty well keeping mud etc off the sides of the truck and the after-market running boards I added. I didn't think much of them when I first got them, but the work.
