Ford announced in 2025, starting with Job 2 production, the Flash will come with a 123 kWh battery instead of 131 kWh. These are starting to show up in dealer inventory now mixed in with the 131 kWh battery and dealer sites may not indicate battery size. NOTE: The MSRP is the same for both!
There are a couple of ways to determine battery size. First, it will be clearly shown on the Window Sticker:
Second - if sticker isn't available, the 8th character of the VIN tells you battery size (I added a mnemonic to help you remember
"7" - 131 kWh e.g. 1FTVW3L70SWG0237x (lucky 7)
"U" - 123 kWh e.g., 1FT6W3LU0SWG1512x (U screwed)
Third Way:
123 kWh will show 300 mile EPA range
131 kWh will show 320 mile EPA range
The codes above are for the single 48-amp AC charger (standard on all Lightnings beginning in 2024)
However. like the ER Pro, the Flash does offer a fleet option for the dual AC charger (80-amp):
"M" - 131 kWh dual charger 1FT6W3LM0SWG0131x
I haven't found a Job 2 123 kWh with dual charger yet. Also, the fleet-only Pro ER will have a 123 kWh battery going forward.
Finally, "K" is the code for the Standard Range 98 kWh battery with single charger as found in Pro and XLT.
Single or dual charger is also shown on Window Sticker next to battery size:
The codes above are specific to '24 and '25.
For '22 and '23 (all trims):
"L" - Standard Range, 98 kWh, single charger standard
"V" - Extended Range, 131 kWh, dual charger standard
Third Way:
