Starlink Mini, Does it FIT under the sunroof privacy shade?
daczone
2024 Lightning Lariat
Just picked up a Starlink mini to install on my sunroof. Anyone know if it fits under the sunroof shade? Any install picks?
Edit: I realized this was a stupid question.... If fits... until you open the sunroof, then it's in the way.
K6CCC
Glendora, Calif.
If you mean install the Starlink under the sunroof glass, you will likely find that does not work well. Most of the modern additions to glass that makes it block sunlight, also blocks Radio Frequencies. This is particularly true for reflectorized glass that is very commonly used in building construction.
daczone
daczone
BUT it fits on the dash.
Ford F-150 Lightning Starlink Mini, Does it FIT under the sunroof privacy shade? IMG_9340
It has a perfect view of the sky
Ford F-150 Lightning Starlink Mini, Does it FIT under the sunroof privacy shade? IMG_9341
Picture (Lots of reflection of the crap in my shop) looking down on the front windshield.
Ford F-150 Lightning Starlink Mini, Does it FIT under the sunroof privacy shade? IMG_9320
Which gets great results.
Looks like I will be 3d printing a mount for it there.
I need this for work. Not to drive around and be connected, but to have connectivity in remote locations.
I would say this might be true for a Tesla roof or a new Lexus Opaque roof (changes with the push of a button) but Ford sunroofs and those on our trucks haven't blocked anything in years. Ford has seriously spent little to nothing to make these sunroofs prevent anything from coming through.
vvgogh
Colorado
'23 F-150 Lightning ER
If that were true, your cell phone wouldn't work being surrounded by glass and aluminum. Not in our F-150s.
That said, Starlink uses 10.7-12.7 GHz for downlink and 12.75-13.25 GHz, 13.85-14.5 GHz for uplink. The higher Starlink frequency will see more loss than cell phones.
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
Unless you’re really concerned about having it stolen in said remote locations then this is completely unnecessary. The Starlink is designed to be placed and left out in all weather conditions.
roddiaz1
Rod
Pittsburgh
Don’t you guys find that the Starlink pad/antenna needs to be tilted “just so” to get a good signal. I see other using it flat against the sunroof or flat on dash. I’ve tried that and it wants a tilt towards the NE.
Am I doing something wrong?
K6CCC
Glendora, Calif.
As I understand the original question, the intent is to use the Starlink IN the vehicle (maybe while under way).
I realize that this is a conversation/questions about Starlink, as some may feel the need for it if spending a lot of time in very rural areas, especially in the west...
we use a simple device: T-Mobile whole home internet "in a box", of sorts, as it is simply a plug-in device that provides an easy "always on" wifi signal: $50 monthly.
Ford F-150 Lightning Starlink Mini, Does it FIT under the sunroof privacy shade? 1748428119036-b4
I have been amazed that this device works almost anywhere we go - it plugs into the truck, or our camper, or at home, and is always on. It only takes a 120v outlet, whether at home, in the camper, or while driving in the LIGHTNING. No cables. No coax. Nothing.
having traveled the country in our diesel motorhome several times back in the 2014-2020 timeframe, we experienced the 'woes' of trying to always have an internet connection. Campgrounds struggled to 'provide' some type of wifi, or, well, in the really early days, the more typical "we have wifi here at the office", then providing some basic wifi to the campground sites, which wasn't always sufficient for even checking email, and, of course, barring ANYONE from trying to 'stream' anything...
we had some time trying to use some type of 'antenna' to capture the internet, but, back in the day, those were costly, slow, capped, and not always available if not in the 'full' clear sky. Camping is usually in the woods... oh well. Satellite TV was similar.
when cell phone HOT SPOTS became available, and much easier, these made a lot more sense, and were a lot easier, although the Hot Spot 'caps' and cost made this an issue, as well...
there have been a LOT of changes in the world of the internet in 10 years.
and, to put this in perspective, as we have it 'so easy' now... many campgrounds still have vestiges of the 'old' technology... not only 'cable tv' coax outputs, but, yes, PHONE SERVICE outlets... yes, the type where you plug in a REAL phone......... : / .........times are a changin'
Ford F-150 Lightning Starlink Mini, Does it FIT under the sunroof privacy shade? 1748428137555-l9
trev5150
Banned
Banned
Banned
Trev
Except he stated in the third post that it was not for while driving.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
Did you ever make a mount for this?
drewfaulk
Atlanta
I can confirm the Starlink Mini will fit between the glass and shade (i.e. shade closes) with this mount in the Lightning (and receives a signal without issue):
https://www.amazon.com/dp/B0DT5QN9BR?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
You have to put it on the back (stationary) panel, as the distance between the shade and glass gets "shallower" the closer to the front of the vehicle you get. You cannot open the sunroof glass more than 6-8 inches when installed, and you cannot tell it is there when the shade is closed.
mq019
2023 F150 Lightning Lariat ER
I have this exact mount and it works great - easily clears the shade and good connection to starlink through the roof even with it flat (the EBS phased array antenna in this thing is amazing!).
Question for you though - how are you getting the cable out of the sunroof area? I haven't looked too closely but it seems like they have the trough sealed pretty will (which is good!), but I'd like to be able to close the shade completely with the antenna up there, so need a way to get the cable out of that area.
