B177y
- First Name
- Bill
- Jul 16, 2024
- Olympic Peninsula, WA
- '24 Pro SSV ER Max Tow, '23 MME Premium, '20 Bolt
It seems like there were a couple of '24's where the Comma didn't work, but then a whole lot more '24's where the Comma does work, mine included after adding the ACC & LKA mod with the radar CCM. Encryption is coming, maybe even in the '25's but I don't think anyone has tried a Comma in a '25 yet to report.A friend and I here in Tulsa, OK were just talking about Comma a few days ago. I thought they started encrypting some things on the 24'+ on the FD bus which prevented Comma from working? Is there already a forum post for the Lightning detailing the installation of Comma,, if not can you start one. I'll go ahead and give it a try if someone will do a bit of DIY post on it.
The main Comma thread to follow on the Lightning forum is here. The better thread to follow is on the ICE F150 thread here. Follow forum member @Ajzride on Lightning, Mach-e, and ICE F150 forums as he's a developer (maybe the only developer?) of BluePilot which is a Ford specific fork of SunnyPilot which is a fork of stock OpenPilot... Or something like that.... If you really want to get into the BluePilot weeds, the Discord link is here for SunnyPilot. Go to the #Ford section for the BluePilot info.
The Lightning does require modifying the USB cable by adding 2 resistors. The parts list and discussion starts around page 22 here. @UncleTony is working on some cleaner coupling prototypes with the resistors built in.
Those threads should get you up to speed. Like this thread, I had to read the entire thing start to finish a couple of times, then I still had questions and made the same mistakes but I had a little bit better understanding.
