mkuntzman
Michael
2024 F150 Lighting Lariat
Construction Estimator
I am happy to help with any sort of testing for this AC problem. Do you need anything from me?
Correction - I am still having AC problems. I don’t know if it did work that first time or if I just thought it was working. But it has not worked the last three drives. What do you need from me to help problem shoot? The breakout board did work for the startup alerts. I have forescan if that is needed for diagnosis
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Clear all DTC's with forscan and see if the AC issues persist. It may be a stored code from before you had the board. If the AC still doesn't work once you clear the codes, rescan and send me the codes in the DTC list.
Sorry for the late reply, it's been a busy day.
mkuntzman
Michael
I cleared the codes and it seems to be working fine. I'll update you if it starts having any issues again! I was able to one day ship the breakout board from amazon (y)
UncleTony
Tony
Gotcha. I think i mixed you up with another user. But good news that the breakout seems to resolve the AC issues.
BlakeGJ
Blake
Chandler, AZ
2023 XLT ER
Is there a reason not to add the a10-a11 resistor to b10-b11 too so it is reversible?
UncleTony
Tony
You can, but it will lead to over-termination since you will be adding termination to buses that are already properly terminated. Its all outlined in previous posts here.
(B10/B11 also wouldn't do anything for reflections.)
UncleTony
Tony
I am working on a way to make it bi directional. But im honestly not putting a ton of time into it considering you're not going to be reinstalling it enough for it to realistically matter.
Edit: If you are thinking it only plugs in one way. That is not the case, the board is agnostic to 180 degree rotations. Flipping it end over end is where you lose the proper orientation.
UncleTony
Tony
On that same topic, what do ya'll think about this case design? Don't judge the print quality as its set for draft. But in terms of the coloring. The blue is intended to indicate the direction that should face the truck.
Open to notes. I was just thinking this allows an obvious indicator for those looking for it and is hidden when installed. (Granted it likely won't be visible).
Ford F-150 Lightning Comma AI self driver assistant 20250719_222832
Ford F-150 Lightning Comma AI self driver assistant 20250719_222903
watts/up
23 Pro SR
Smart. Trying to think of a better solution but I can’t at the moment.
UncleTony
Tony
My original design was going to add a lightning bolt to the truck side, but id need to buy smaller nozzles for that and this felt less extra lol.
watts/up
23 Pro SR
Funny you posted this. I was just thinking that adding a lightning bolt and a comma on the corresponding sides would be an option but didn’t know if it was feasible. I know pretty much nothing about 3D printing.
UncleTony
Tony
That was actually the original thought for these. They are just small for that level of detail. I would have to buy the .2 nozzles to see if it is actually a feasible idea. I have managed to get some really fine details from my printers, but I kind of started thinking about how little these will be seen once they are installed. I plan on putting mine inside the mirror housing.
