potato
BC, Canada
2023 F150 Lightning XLT ER
Otherwise, if you are on a job site, it may be best to keep the truck powered on (even though it's in drive-off condition) so it doesn't auto-stop PPO.
It's not in drive off condition unless you leave a key inside. It won't shift out of park.
Rocky514
Michael
2023 Ford Lightning Lariat
Rail Traffic Controller
Can you explain what you did for this one? It is also known as IPC Quick Boot (IPC = instrument panel cluster or dash). There have been several attempts at this but iirc they were unsuccessful. I’ll add to post 1. Thanks!
I'll try to look into it when I get a chance as I am at work, but I think it was this one from the
Disabling F-150 Lightning's Beeps, Dings, Chimes, Honks, Bings, Bongs, and Dongs thread:
  • BONUS: IPC quick boot. This disables the annoying (albeit inaudible) Ford advertisement that takes over your screen when the vehicle boots. IPC 720-07-01 xxxx xxxx 2xxx
Do you get to a meaningful screen any sooner? I dont mind the display, but the amount of time everything takes is annoying.
Rocky514
Michael
I feel like it is a lot better, imo. If only I could get wireless AA to kick in quicker, lol.
@Rocky514 your videos are of the Sync screen. But the mod is on the IPC. That’s the Instrument Panel Cluster, the screen behind the steering wheel where speed and battery are displayed. Folks have reported earlier in this thread that the IPC boot graphics don’t change with this mod. See discussion starting at post 289.
I originally had this mod in post 1 - as well as others from the Beeps, Dings thread. But I removed this one since folks said it did nothing. It came from the ICE forums.
I’ll try to do before and after testing soon.
NeighborGeek
Steve
2025 F150 Lightning Flash
I just tried using Forscan for the first time. After saving the data from all modules, I tried to enable Silent Mode. I was able to make the change in the APIM module successfully, but when I try to write the changes to BdyCM I get an error "Writing Blocks Failed - Incompatible configuration".
The write seems to work at first, and the progress bar goes all the way to the end before jumping back to about 50%. Then I hear a couple of clicks, and it seems like the infotainment system restarts, then the error comes up.
Any idea what I'm doing wrong to get this?
When you make a suggested change you are only changing the character that is shown to change right? You don't mess with the last two characters? In most all cases as those are check sums that the system will calculate for you.
NeighborGeek
Steve
Yes, only editing the specific characters. Though, for the first BCM setting, that's the whole thing except for the last 2 characters.
What it seems like is the write finishes and the module restarts, but forscan is still trying to do something and fails since the module is rebooting.
That said, I just realized after posting that I do see the silent mode option in the settings now, and it did seem to be muting the walk away lock honk, so maybe it worked.
My only other thought is make sure you have the most current version of FORScan. The 2024's had issues also when they first came out because FORScan didn't fully support some 2024 modules yet. Might look back at this thread to see if any 2025's installed something with the BCM successfully (only a couple mods involve the BCM).
Could be you have discovered an issue but I would think others would have reported it by now (unless BCM specific).
Rocky514
Michael
My main concern was the Sync screen, I honestly thought that was what it pertained to.
So I did a lot of testing using both the default "4" as well as "2" and "0" and didn't notice any difference on the instrument cluster. But as I was comparing videos afterwards I noticed a change in the Sync screen.
However, it may because the truck was asleep. A lot of my tests were back to back (key off, then key on) so it may only be due to that and not the mod.
With that said, with the default value of 4 I get the following 1.5 second "Lightning Flash to Ford logo" splash screen before it starts to show Radio. But only if the truck was off for 10 minutes prior. If I restart, the sync screen goes straight to Radio station - rather quickly. No splash screen.
With your value changed, do you ever see this splash screen when you start? I'll try 0 and 2 again when I get a chance. I would do this without being in AA or CarPlay as that definitely adds delay. Just have a Sync app like Nav, Radio, Tire Pressure, etc.
There are tons of interesting customization options buried in the Lightning’s modules — from display tweaks and color changes to hidden menus and features.
The challenge? Not all of them work, and many haven’t been tested or documented.
To help organize our collective knowledge, I’ve started a collaborative Google Sheet where we can track Forscan projects and discoveries:
? Google Sheet – Lightning Forscan Projects
The idea is to shift from isolated trial-and-error to a more community-driven approach. Whether you're exploring something new or verifying an existing tweak, we can work together to document what works — and what doesn’t.
If you’ve got an idea for a project or a change you’ve been curious about, feel free to jump in. Add a new tab for your project, jot down what you find, and let’s build a central resource we can all benefit from. Want to help on a current project, do some testing and record the results.
A couple things on my radar but not on the sheet (yet):
-Adaptive Steering Manual Menu – appears in both the APIM and IPC but looks disabled on my truck.
-MyColor options – also in both modules, possibly just waiting to be unlocked.
Let’s see what we can uncover!
The Mach-E and older versions of the ICE F-150 had multi-color ambient lighting. We have only had Ice Blue (a single color LED). I suspect this parameter refers to the custom color you have selected if you have the Mach-E (or other models that support multi-color).
FYI, there is somewhat expensive mod where you can change all your LED's from Ice blue to the multi-color. Then you can enable a menu in Sync to select your color. I documented it here.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1753054938605-2n
This is on my own Sync screen but notice the graphic is of a Mach-E!
Mostly i was looking at this. Zero idea if it works on the Lightning/F150, but looks fun to try.
Edit: Just tried, didn't change anything, no "MyColor" options appeared as best I could see.
Did some messing tonight and here is what I found.
Police Dark Mode didn't seem to do anything
Pip did add a button to some camera screens, but it didn't actually function
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 20250720_222519
Tried adding various adaptive steering. Adaptive steering manual, etc (all clustered together in forscan easy mode) and did not observe any changes.
On the plus side the IOD displays ARE the Sync (12") "cards" that appear on the right of say the Audio display. This has Nav, Phone, Trip, etc. Some were able to be added although Tpms and aux never showed up.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 20250720_221009
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 20250720_221018
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 20250720_221125
