WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Need a little help trouble shooting, open pilot didn’t work, tried blue pilot 4.0. The pictures show the plug I was using .
Still not working , I did notice that all of the error codes are still active with only the usb-c is plugged in , with or without the comma being plugged in! Can’t I just solder the 360ohm resister into the “Ford Q4” harness? If so what wires?
Lawrence
25 F150 Lightning Lariat
Instrument Technician
could you try a vpn to route to different regional server/
Ajzride
Alan
Houston
Eng
Well, you can't install a VPN on the comma, and he said his networking skills were weak, so I doubt he can set one up on his router. I'm not sure what happens when you fire up a VPN app on your phone and then hotspot, but it could be worth a try.
WilliamRobert
happily retired!
I went back and read the posts, it looks like this was resolved. What is the question?
Ajzride
Alan
Houston
Eng
B177y
Olympic Peninsula, WA
This might explain my situation. Home internet is straight T-Mobile router. I use a VPN on my T-Mobile phone. Comma download worked when tethered to phone hotspot. I'm in a fairly rural area, so it's likely that my home internet and phone are both on the same T-Mobile tower. VPN on the phone might be the difference.
EDIT:
I have had the same issue a couple of different times now where the phone tethering allows the download but the home internet will not. It's all starting to make sense now.
Most of the time, home internet does work though.
Reactions: EVO
WilliamRobert
happily retired!
It still doesn’t work, a different cable stopped the errors of the truck, then the comma got an error.
Ford F-150 Lightning Comma AI self driver assistant IMG_0931
Ajzride
Alan
Houston
Eng
EVO
Randy
2024 lightning flash
electrician
Weak but better then the average person. My router allows me to run a VPN. Your cell idea would be easy. I have Nord installed on my phone. If this issue comes up again. I will try these suggestions and let every one know the results. Thanks again for all the hand holding. It is greatly appreciated!
campalex24
Alex
2024 Ford Lightning Flash
Hospistalist
Okay, so I need some help.
I’ve tried to install the comma 3x running blue pilot 4.0 in several ways on my 2024 lightning flash edition. Sometimes it will intermittently work, sometimes I get the immediate CAN Bus disconnected likely faulty cable error.
it will occasionally also flash a different error I have included in the pictures, this is far less common.
Ford F-150 Lightning Comma AI self driver assistant IMG_4306
Ford F-150 Lightning Comma AI self driver assistant IMG_4297
Ford F-150 Lightning Comma AI self driver assistant IMG_4294
Ford F-150 Lightning Comma AI self driver assistant IMG_4307
I have put in the lightning adapter with the following configurations.
comma3x harness Q4 ford harness (first one they sent, got lost in mail, let’s call this *1)
harness 1 —> comma long obdc cable —> lightning adapter—> short thunderbolt 4 cable —> comma
harness 2 w/ same setup
Harness 1 w/ Long obdc —> lightning adapter —> long obdc cable 2 —> comma
harness 2 w same set up
harness 1 with usb 4.0 —> lightning —> usb 4.0 comma
what am I doing wrong?
(have pulled fuse 32 several times to reset/make sure)
Ford F-150 Lightning Comma AI self driver assistant IMG_4298
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
I believe thats a Thunderbolt cable, which is the same form factor as USB-C.. and should be compatible, but perhaps that's the problem?
Ajzride
Alan
Houston
Eng
CAN Bus Disconnected: Likely Faulty Cable means exactly that, we have a problem with the USB cables. Let's look at your configs below:
This should work, so one of these cables or the adapter must be bad.
Harness 2 w same set up
This will not work for sure. Two long ODBC cables is a problem (known from experience)
Cruise Fault: Restart car is a different message, this means the Ford Radar has an error code in it. Usually this happens during hard rain, but it is possible the comma did something to cause it to fault.
I have never heard of USB 4.0, that must be new, and I'm not sure how it will work with comma.
follow this article, start with just the short USBC cable that comma includes (there should be no errors and no need for the coupler when using the short cable). Come back here with any questions.
https://bluepilot.dev/2025/08/15/i-...r-i-get-a-canbus-error-and-alerts-on-my-dash/
Reactions: EVO
