Blue cruise 1.4 update not completed
Theredshift
Kentucky
Lightning
Usps
My blue cruise says update 1.4 not completed.
Any ideas why and if so, how to complete?
It happened a couple days ago and I have my updates auto for 1 a.m. any day.
Thanks
Theredshift
Theredshift
Kentucky
Lightning
Usps
Failed updates are often related to low 12v battery.
The one thats in the frunk?
Why would that cause an issue on an update? It was plugged in on class 2 charger at the time
Bestword57
2023 F-150 Lightning Lariat Ext. Range Enhanced Tow, 2013 Chevy Volt.
Network Administrator
Thanks Tim, but what is the voltage threshold for updates potentially failing?
Tfarrell73
Tim
New Lenox, Illinois
23 F150 Lightning Lariat ER
I believe it is a certain % SOC of the 12v battery. Below 70% maybe. It can be read with an OBD adapter.
Plugged in and not charging does nothing for the 12v battery.
For some updates, as high as 80%. Drive for 30 minutes, then manually apply the update.
Bestword57
That's correct. Apparently, you can adjust the target SOC using FDFS to around 90% from the default on some models that for some reason are pre-set at around 80%. I was reading that this can cause result in SOC fluctuations up to 98% though, so not sure if I want to try changing the default SOC target. I'm going to research it some more.
Bottom line is I've seen at least one update fail to install on my Lightning.
If you don't want to drive, put the battery (via the jump posts on the passenger side) on a trickle charger overnight, then do the update.
Or, put a battery charger on it for a bit, then try.
Theredshift
Theredshift
Kentucky
Lightning
Usps
Well I tried looking for a way to manually get it, but.cannot find an option for that.
I checked under software update, and nothing.
Thanks
Thanks
If the campaign has aged out, you will need to wait for the MoCo to reissue it to your truck.
Thanks
"Not completed" means the OTA trigger is no longer active. There is nothing you can do at this point but wait for it to be resent.
Ford Motor Company
Official Ford Account
F-150 Lightning
I'll send you a message to get some details to see what I can do to help.
Scrappy
Chandler, Arizona
2023 Ford F150 Lightning ER Lariat, 2021 Mercedes GLE, 2024 Polaris Xpedition
Electrical Engineer
Brian,
I am in the exact same boat. I drove my truck ~160 miles last Thursday, put it on a Level 2 charger that night and saw a message Friday morning that it tried to install BC 1.4 but failed.
I have it on a battery tender right now but that is probably pointless now that I missed the lottery.
Anything you can do for me?
Thanks!
Marc
Marc
Roswell
23 Lariat and a 25 Rivian R1S
insurance agent
i'm in the same boat! I had the update not finish and I was on the charger that night also.
Marc
Marc
Roswell
insurance agent
i'm in the same boat. my Blue Cruise 1.4 update did not complete and i was charging at home. It never gave me an option to complete it.
