Ford Won't Give Me the Pro Charger 80A
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
If I bought a new one today, I'd sell the free unit and get a Gen1 Tesla that's capable of 80A and get adapters. If the industry keeps trending away from CCS and toward NACS, then your future proof.
That math changes if you want to hedge against whole home backup systems.
Thanks everyone. I'll be sure to keep an eye out on these other options. The good news is that Cloninger Ford down in Hickory, NC, came through for me and swapped out the 48a charger for the Pro one they told me I'd get. It took a while, but I've got my QMerit installer lined up in a couple of weeks to get it hooked up.
While we had a few bumps, I'm grateful to the team down there for getting me everything they told me I'd have as best they could.
If you don't plan on using HIS, you may regret swapping the small light cable and connector of the 48A charger to the bigger, heavier Pro. I sold my FCSP and got a 48A charger. Smaller box on wall, lighter cable, and didn't have the bulkier CCS-1 connector.
It has been reported that now Ford may be giving out the Emporia 48A charger which is a great unit.
That Emporia is a very high quality unit. Kinda surprised it's so inexpensive.
SunRun royally screwed up when I bought my truck and sent me two CSPs. Sold one on eBay and bought an Emporia. Installed a CSP at my house and the Emporia at a family members house. Worked out great.
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
I did the same. Sold my free FCSP and bought a Tesla Wall Connector. Recently I replaced the NACS Only Gen 3 Wall connector with a Tesla UNIVERSAL Wall Connector (J1772 & NACS) at both my house and my cabin.
The Universal works well for us with its built in either J1772 or NACS plug, since we have Tesla’s and Ford’s.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
My truck was ordered with the optional power cord kit so it's already J1772/CCS and then has the NACS adapter I can pop onto it also. So I suppose I'll just keep the free Ford unit, if I ever get it, and if the wife gets some kind of EV car one day we'll be alright.
Note if your wife gets a plug-in hybrid that only has a J1772 port, you will not be able to use the FCSP since it has the CCS-1 head. You can get yet another bulky adapter. Or just get rid of the FCSP and buy a charger with the svelte J1772 connector (or the Tesla universal).
Thunderstorm Lite - designed for the Ford Charge Station Pro
Caliber357x
‘23 Lightning Platinum
Note that if you just want home backup, it works perfectly fine to run a cord from the pro power 30A outlet in the bed. There is a little complication involving the GFCI but nothing that an electrician can’t figure out (see threads on the topic).
The only advantage of the home integration system is that you get an automatic transfer if the power goes out while your truck is plugged in. I believe that it is also limited to supply 30A of power to the house (based on other threads here). It saves you the hassle of finding the cord and plugging it in, possibly in the dark, but at a fairly large cost in money and complexity. The advantage of using a generator plug on the house side is that you can use it with other devices - like generators or other trucks (one of whch, ahem, supplies 50A). Future buyers will be more impressed by a standard generator plug than a Ford specific device.
This is the way. My electrician is installing a HIS at someone else’s home and it’s been a 9 month ordeal. I said no thanks and had him install a 30 amp generator plug with an interlock on my panel. I can power my whole place (well pump, heat pump water heater, lights, fridge, and all three heat pump mini-splits. Cost to install the gen box and interlock was $700, and the cable to the truck sits in a nice box next to the gen box.
flyct
Jerry
South Florida
Blissfully Retired
The Ford supplied NACS adaptor is only for Tesla Super Chargers, not home chargers. It your wife gets a EV one day with a Tesla NACS connection that adaptor will not work for home charging.
Yeah, that one. It's a monstrosity :facepalm: . Why go all though all that. Just sell the FSCP and get a normal sized J1332 or NACS and eliminate the red box part.
I sold my Charge Station Pro for $1,000 right after I got it, so I'm not advocating using it. BUT, if one uses it already, then this solution is better than cutting pieces out of adapters or cords.
WXman
Central Kentucky
www.facebook.com
The Ford supplied NACS adaptor is only for Tesla Super Chargers, not home chargers. It your wife gets a EV on day with a Tesla NACS connection that adaptor will not work for home charging.
So the Ford supplied home charger with a Ford supplied NACS adapter won't fit a Tesla vehicle with a NACS port?
That's the dumbest thing I've ever heard of. What I'm learning very quickly is that the most difficult part of EV adoption is figuring out all the various connection types. Reminds me of when cell phone companies all used different ports, so that every time I bought a new phone I also had to buy a new charge cable. It's just idiotic.
flyct
Jerry
South Florida
Blissfully Retired
Adapter roulette:
The ONLY adaptor that Ford Supplies is an adaptor that allows you to charge a Ford EV at a Tesla Fast Supercharger. It cannot be used to charge your Ford at a Tesla Home Charger
To charge any Tesla on a Ford Charge Station Pro Home EVSE, A2Z sells an adaptor that can be used. This is the only one that I know of, but there may be others. https://a2zevshop.com/products/thunderstorm-lite?ref=Typhoon It will not work at a CCS DC Fast charger.
EDIT:
To confuse things even more, The Ford Connected Home Charger (not the Ford Charge Station Pro) has a simpler J1772 plug without the 2 pins at the bottom. Every Tesla comes with a J1772 to Tesla AC fast charger adaptor. Tesla supplied J1772 to NACS AC adaptor fits any J1772 cord, including the Ford Connected station, but it will not fit the FCSP Ford Charge Station Pro.
On the picture below: The Blue handle is a J1772 and the Green Handle is a CCS handle. When using DC Fast Chargers the 2 extra pins on the bottom of the CCS supplies DC High Voltage to the vehicle. When charging at home these 2 pins are not used. Ford repurposes those 2 pins when using their HIS, Home Integration System to power your house.
Ford F-150 Lightning Ford Won't Give Me the Pro Charger 80A 1755712996548-4l
