2023 Lariat that was Buyback/Lemon
Sleazy-E
Greenville, SC
2023 Antimatter Blue Lariat ER
Hello all,
Longtime, first time. I was looking at a truck for sale with a price that seemed to good to be true and upon further review I discovered it was bought back by Ford earlier this year due to battery issues. Below is what the dealer has provided but I’m an idiot and was hoping y’all might be able to decipher what exactly the deal is and if you’d run away from the truck.
Thanks!
Production Date14-MAR-2023Warranty Start Date05-AUG-2023
Selling Dealer121299Selling CountryUSA
GSAR Claim KeyTrx CodeTime In ServiceLabor HoursDealershipDIST (Miles)Repair DatePrefixBaseSuffixDoc
Details110809923S3021TIDELANDS FORD222308-SEP-2023***245860A
Customer CommentsREAR LIGHTBAR REPLACEMENT
Tech CommentsREMOVED AND REPLACED REAR LIGHTBAR
Details224896923B5750.6TIDELANDS FORD894504-DEC-2023*10D672*248920A
Customer CommentsHIGH VOLTAGE BATTERY MODULE REPLACEMENT ANDOR BATTERY ENERGY CONTROL MODULE BECM SOFTWARE UPDATE
Tech CommentsINSTALLED BECM UPDATES AS PER RECAL L23B57
Details2443203156.5TIDELANDS FORD894504-DEC-2023NL1Z78044D70BD248920C
Customer CommentsCUSTOMER STATES THE DASH IS SEPARATING ON THE LEFT SIDE UPPER PORTION OF THE CLUSTER SURROUND. PART WAS ORDERED AND SHOULD BE IN. PLEASE INSPECT AND ADVISE.
Tech CommentsREPLACED UPPER DASH DUE TO MISFIT AT HOLD DOWN
Details2250111153.1TIDELANDS FORD894504-DEC-2023*7G273*248920G
Customer CommentsCUSTOMER STATES THERE IS A CLICKING SOUND WHEN ACCELERATING. CUSTOMER MENTIONED TSB 22-2395 RELATING TO THE SAME DESCRIBED NOISE. PLEASE INSPECT AND ADVISE.
Tech CommentsVERIFY NOISE. PERFORMED TSB 22-2395. REPLACED FRONT AND REAR ANTI- TING WASHERS AND REQUIRED HARDWARE. ROAD TEST AFTER REPAIR. NOISE GONE
Details2250085150.2TIDELANDS FORD894504-DEC-2023NL3Z17B968AA248920D
Customer CommentsCUSTOMER STATES THE LEFT FRONT LOWER VALANCEWONT STAY CLIPPED IN FULLY. LOCATED NEAR WHERETHE LF FOG LIGHT WOULD BE. PARTS WERE ORDEREDAND SHOULD BE IN. PLEASE INSPECT ANDADVISE.
Tech CommentsINSTALLED FRONT VALANCE DUE TO WARP AGE
Details248672723B7060.3TIDELANDS FORD895025-JAN-2024*10C679*250642A
Customer CommentsBATTERY MONITOR SENSOR REPLACEMENT
Tech CommentsBATTERY MONITOR SENSOR REPLACEMENT PERFORMED ON 248920 12/04/23. RO OPENED PRIOR TO RELEASE OF RECALL. USING NEW RO NUMBER FOR CLAIMING PURPOSES ONLY ML3Z10C679B
Details3261611160.8TIDELANDS FORD1090329-JAN-2024ML3Z1523201G250748A
Customer CommentsCUSTOMER STATES THE LEFT FRONT WINDOW NEEDS ASSISTANCE FOR IT TO ROLL UP AT TIMES. OTHER TIMES IT TAKES 3-4 TIMES FOR IT TO ROLL ALL THE WAY UP. PLEASE INSPECT AND ADVISE.
Tech CommentsVERIFIED CONCERN. FOUND BINDING WINDOW REGULATOR. REPLACED WINDOW REGULATOR AND RETEST. TEST OK
Details326107322G0660.7TIDELANDS FORD1090329-JAN-2024*3F791*250748C
Customer CommentsHEATED STEERING WHEEL PERFORMANCE U PGRADE
Tech CommentsREPLACED SCCM AND STEERING WHEEL. PROGRAMMED SCCM. ENABLED HEATED STEERING WHEEL
Details5837702PRENT150BEACH FORD2514203-OCT-2024*RENTAL*730817D
Customer CommentsCUSTOMER LOANER VEHICLE. R-10, VIN 1FTFW3LD7RFA30664. DATE OUT 10/03/2 4
Tech CommentsCUSTOMER LOANER VEHICLE. R-10, VIN 1FTFW3LD7RFA30664. DATE OUT 10/03/2 4
Details583758124P24150.3BEACH FORD2514203-OCT-2024*14A626*730817I
Customer CommentsREPROGRAM THE FRONT HATCH CONTROL M ODULEFHCM
Tech CommentsPERFORMED FHCM SOFTWARE UPDATE AND POWER HOOD INITIALIZATION PER RECALL INSTRUCTI ONS
Details5837513E83150.7BEACH FORD2514203-OCT-2024ML3Z13K359BA730817A
Customer CommentsCUST STS TURN SIGNAL DOES NOT CANCEL, SEEMS TOGET STUCK WHEN TRYING TO TURN IT OFF. PROBLEMOCCURS MOSTLY WHEN SIGNALLING A RIGHT TURN. CHKAND ADVISE
Tech CommentsVERIFIED CUSTOMER CONCERN. CHECKED FOR CODES. FOUND NONE. CHECKED FOR SYMPTOM CHARTS AND PINPOINT TEST. FOUND NONE. REMOCED MULTIFUNCTION SWITCH AND TESTED WITH KNOWN GOOD PART. WORKS WITH REPLACEMENT PART. ORDERED NEW MULTIFUNCTION SWITCH. REPLACED SWITCH AND RETESTED. TURN SIGNAL INDICATOR SWITCH NO CANCELS AFTER TURN.
Details583994024B56151.9BEACH FORD2514203-OCT-2024*14G647*730817H
Customer CommentsINOPERATIVE FRONT PARKING SENSORS - SOFTWAREUPDAT E IMAGE PROCESSING MODULE A
Tech CommentsWHILE PERFORMING RECALL GOT ERROR C OM.FORD.OTX.COMMA ND.EXCEPTION.FDRSR UNTIMEEXCEPTION: PROBLEM EXECUTING HEX REQUEST. CONTACTED HOTLINE TECHNICAL ASSISTANCE. AFTER RESEARCH WAS ADVISED TO USE DCA 8000 BATTERY TESTER AS POWER SUPPLY. USING TESTER RAN IPMA PROGRAMMING FOR A THIRD TIME. IPMA PROGRAMMED SU CCESSFULLY
Details6111878E83164.6BEACH FORD2621407-NOV-2024NL3Z14A303C732984A
Customer CommentsCUST STS CHARGER NOT CHARGING CORRECTLY, BATTERYPERCENTAGE IRREGULAR. SOMETIMES THE CHARGINGLIGHT IS ORANGE, SOMETIMES IT IS BLUE. CHK ANDADVISE
Tech CommentsCONFIRMED VEHICLE NOT CHARGING CORRECTLY. SCANNED, FOUND P2C85 PRESENT. FOLLOWED PPT AL. AL1- TESTED SYSTEM WITH KNOWN GOOD EVSE CONNECTED. P2C85 CAME BACK. CHECKED CHARGE PORT FOR WATER INTRUSION, NONE PRESENT. REPLACED CHARGE PORT(HARNESS) (14A303) CLEARED FAULTS AND RETESTED SYSTEM. CHECKED MULTIPLE CHARGERS AND ALL WORK FINE NOW.
Details7614897E831822.2BEACH FORD2983207-JAN-2025NL3Z10C666E736509A
Customer CommentsCUST STS EV CHARGING SYSTEM WILL NOT ALLOWPROPER CHARGE. VEH IS MAINLY CHARGED AT HOME ON240 CHARGER. SEEMS TO HAVE REVERTED TO HOW ITWAS BEFORE REPAIRS PERFORMED ON RO 732984. WILLNOT ACCEPT A CHARGE PROPERLY OR IS CHAR GINGEXCESSIVELY SLOW.
Tech CommentsCONFIRMED STORED FAULT CONCERNING CHARGING SYSTEM. P2C85- HYBRID EV BATTERY VOLTAGE EXTERNAL ISOLATION FAULT. PERFORMED PPT AL. AL1 CLEARED FAULTS AND CONNECTED TO KNOWN GOOD CHARGER. PERFORMED SELF TEST. CODE RETURNED. AL2-INSPECTED CONNECTOR FOR WATER INTRUSION. NO CONTAMINATION FOUND. INSTRUCTED TO REPLACE CHARGE PORT/ HARNESS. REPLACED THIS LAST VISIT FOR SAME CODE/ CONCERN. CONTACTED HOTLINE FOR FURTHER DIRECTION. WAS DIRECTED TO UPDATE ALL MODULES AND DRIVE VEHICLE THEN CHECK FOR UPDATES AGAIN (M-TIME PUNCH FOR THIS). PROBLEM STILL THERE. INSPECTED CONNECTOR C292 AS DIRECTED BY HOTLINE (OK NO WATER INTRUSION). REMOVED HIGH VOLTAGE BATTERY REPLACED HVB CONNECTOR PART # NL3Z-7G276-A. RETEST. PROBLEM STILL HERE. REMOVED BATTERY AGAIN, INSPECTED CIRCUITS INSIDE AS DIRECTED BY HOTLINE. NO CONCERNS FOUND, REPLACED POS AND NEGATIVE CONTACTORS PER HOTLINE. RETEST. SPW CHARGE CABLE ON A NEW LINE.
Details7565560E83185.2BEACH FORD2983207-JAN-2025NL3Z14A303C736509E
Customer CommentsADD ON LINE FOR ADDITIONAL CONCERN WAS APPROVEDBY __________ ON REPLACE THE CHARGE CABLE PERFSE
Tech CommentsM TIME TO REMOVE CUSTOMER BELONGING IN FRUNK, EVAC AND RECHARGE AC. REMOVED AND REPLACED CHARGE CABLE ASSEMBLY (PER HOTLINE SUGGESTION). CHARGING PROBLEM STILL PERSISTS.
Details8473335RAVIN211CAPITAL FORD OF CHARLOTTE, INC.2988417-APR-2025*RAV*339266A
Customer CommentsRAV INSPECTION: FILL OUT CHECK SHEET. ***** RAV REASON: BATTERY *****
Tech CommentsVEHICLE CHARGED TO FULL BATTERY MULTIPLE OCCASIONS WITH APPROXIMATELY 600 MILES ROAD-TEST DRIVEN WITH NO ISSUES. NO ON- DEMAND DTCS PRESENT AND ALL SYSTEMS FUNCTIONING PROPERLY AT THIS TIME.
Details8473454P86210CAPITAL FORD OF CHARLOTTE, INC.2988417-APR-2025*6007*339266B
Customer CommentsICM STATES TO CHARGE VEHICLE, TO TEST HV BATTERY AND TEST DRIVE
Tech CommentsCHARGED HIGH VOLTAGE BATTERY TO 100% MULTIPLE OCCASIONS. NO ISSUES WITH DELAYED CHARGING TIMES AND BATTERY CONSUMPTION NORMAL. MSP A193261
I only see the slow charging compliant as a point of concern, but post RAV inspection confirms the truck is working as designed.
NOTE The recent era of post COVID supply chain and other supply chain issues hamstrung the MoCo and dealers to fulfilling repairs in a "TIMELY" fashion, but once reacquired, they "EVENTUALLY" got repaired and were eligible for retail sale, much different than 21 years ago when it's was likely an inherent failure that would not be fixed and they scrapped the chassis.
watts/up
23 Pro SR
Buy back is an improper use of terminology as when Ford (Buys back) a vehicle, it's typically destroyed, sometimes they get donated to local voc-tech schools/community colleges and the like for teaching purposes, they are NEVER allowed to be resold EVER.
Disclaimer: Going on 21 year old information as that's how long it's been since I worked for Ford.
What you likely see is a customer trade in, probably due to all the repairs it has undergone since they bought it originally.
I don't think this is true at all. Why would they destroy a vehicle for what typically is a minor issue? There are a handful of users on this forum that have purchased Ford buy-back "lemon law" trucks. Capital Ford of Charlotte is one dealer that has been known to sell a lot of them. Here's a link to Victory Ford who specifically states they participate in reselling such vehicles.
The Weatherman
Dean
South Central KY
What if any extended warranty are they offering, if any?
With at least a 12mo warranty I would probably take a chance. Assuming the price is right.
rdt7
Bob
2023 F150 Lightning (Lariet - ER)
Hello all,
Thanks!
I bought a buy-back from Capitol Ford. It was also a 2023 Lariat. This was May and I've put about 5000 miles on it with no issues. My repair list was not nearly as long as yours however. The vehicle came from CA where buy-back laws favor the owner and many vehicles are returned for more minor issues.
LSUT1GER
Slidell, LA
Computer Engineer
What's the price and warranty?
I would walk away from it regardless.
Ford buys back vehicles, sometimes lemon law, sometimes not, fixes them, and then offers them for sale. Sometimes title is changed to note that also.
efme
'23 F150 Lightning Lariat ER
There is a South Carolina dealer that sells buy back cars all the time. Most of their lightnings are buy backs according to the Carfax
I think that's completely wrong they don't fix and resell buy backs with a branded title. It's clear as day they aren't trade ins
efme
I never said they weren't disclosed. Like I said, the Carfax says buy back. They don't hide it. But it's wrong to say Ford doesn't sell buy backs and we're all misreading trade in as buy back on a carfax
watts/up
23 Pro SR
For me I think what it comes down to is the delivery.
What may have been true 21 years ago may not be true today and (in my opinion) the post should start with that rather than including a disclaimer and then continuing to state that what the user is referring to is a trade-in especially when there are posts on the forum indicating otherwise.
Re-reading your post and follow-up I see where you're coming from and I do appreciate your insight and experience, I was just pointing out the discrepancy as it relates to the question starting this thread.
efme
If you had read my post ENTIRELY you would have known I was talking about what they did 21 years ago when I worked for Ford. I didn't say it was still the case and the reason I put the (21 years ago factoid) in my post.
Ok man. I read the whole thing. Your topic of your reply is a statement as a matter of fact then mentioning a caveat is not the same as starting with the caveat.
All of your replies since is you discrediting yourself. Very odd.
Anyways it's clear Ford sells buy backs from the replies and what is listed for sale online today.
I'm aware of that, I did work for ford for 11 years after all. I stated they buy back and DON'T resell vehicles they have tried to and failed to fix, I'm not talking about lease buy backs or customer satisfaction buy backs, I'm talking about CAN'T BE FIXED buy backs.
And again,....... this is TRUE 21 years ago, I have no idea in this day and age if they resell vehicles they can't fix or not, seems counterproductive to do something like that that becomes a liability not to mention the bad blood and adverts they get from selling broken junk.
Ford has been fixing and reselling both Mach-Es and Lightnings, many with the title noting that.
