Google maps with Carplay now integrated with driver display for some. Possible "fix" is in post 40.
Lytning
Georgia
I just completed a 50 mile round trip using Apple Maps on CarPlay. I had the dashboard display on the trip out, but not the trip back.
RLXXI
S. E. Louisiana
Auto tech
TreyDub
Teey
Ford F150 Lightning Pro
Reboot the truck, disconnect the LVB for 30 mins.
Tried this after your suggestion and still no luck. Wonder what the hell happened. To have it then lose it.
watts/up
23 Pro SR
Just a shot in the dark but are you connecting wirelessly? A forum member previously indicated that only wired connections showed directions in the IPC for them. Not sure why that would matter.
Robocop
2022 Platinum; 1962 Lincoln Continental
Good Day!
I have a ‘22 platinum and google maps works and integrates with my display as well. Just in time for the end of the complimentary Ford nav subscription that isn’t getting renewed.
tearitupsports
Russell
Houston, TX
Good Day!
And you are using CarPlay correct? Android auto has worked for a long time.
Does your walk away lock also work?
did you ever have the dealer do the carplay?
thanks for the info.
usernamed12579124
Houston
2023 Lightning XLT
Anyone know how to turn this off (directions in the dash instrument cluster screen behind the steering wheel)? This just showed up for me and I'm not a fan, but can't figure out how to get it to stop. 2023 XLT with iPhone and Google Maps. Thanks
roddiaz1
Rod
Pittsburgh
If your truck is like mine, just wait a while and it will stop working as it should, then you wont be annoyed anymore. :ROFLMAO:
tearitupsports
Russell
Houston, TX
I think I have figured out how to "jump start" or fix this issue.
I am not sure how, but one of my 2 iphones suddenly started working, so I knew it wasn't a truck issue holding me back.
I connected to carplay with the other phone and began to try and figure it out.
While in google maps on the screen, I changed one of the settings (completely un-related to anything having to do with this feature), but it seemed to trigger something in the code, and now the dash display is working every time. In my case I went into settings (cog wheel) -> route options -> (toggle) saving energy.
For reference both phones have the latest iOS and Google map versions. Both phones now work on the dash display even in wireless CarPlay mode.
Ford F-150 Lightning Google maps with Carplay now integrated with driver display for some.  Possible "fix" is in post 40. IMG_2614
Ford F-150 Lightning Google maps with Carplay now integrated with driver display for some.  Possible "fix" is in post 40. IMG_2615
roddiaz1
Rod
Pittsburgh
That does make sense, because when it wasn't working for me, on the iPhone I would no longer see "my vehicle" selected as an EV, whereas before I did. So by selecting Saving Energy, you're toggling the EV feature(s). Perhaps.
Magendi
Philly area
Lightning Lariat
You are my hero!!! That worked. Immediately when I toggled that option it showed up. Even after toggling it back off it stayed there, which is super awesome.
SmoothJ
New Jersey
2022 F150 Lightning
I was the one who reported this initially in the other thread, and I use it often to say this isn’t a fluke. My phone has been plugged in charging, and not plugged in… all worked fine wirelessly.
