Naveen
Naveen
Louisville, Kentucky
F150 Lightning 2023 XLT- 311A
This is what I'm seeing in FORSCAN..
7D0-05-01 xx*xxxxxxx--0 =EH Electronic horizon Off • EHT MPP + Stubs8 =EH Electronic horizon EH • EHT MPP + Stubs
4 =EH Electronic horizon Off • EHT MPP + First Level Sub PathsC =EH Electronic horizon EH • EHT MPP + First Level Sub Paths
I dont see "1" listed anywhere. I will keep searching. Also i find it mentioned here -
https://www.f150gen14.com/forum/thr...atabase-spreadsheet.1578/page-278#post-673115
watts/up
23 Pro SR
I recommend that you head over to the FORScan thread, read through that, and then start with something simple that doesn't require making hardware changes to your truck. I don't recommend making any ACC-related changes until you've actually made the required wire and module upgrades.
Also, make sure you're backing up your existing settings.
Kudos for researching this before making changes. I looked at my database of other Lightnings. And like you, I see that many of the XLT 311A trims do have a "1" in that position. But others have a "0". This is true for model years 2023 and 2024. Interestingly all 2025 XLT's have a "1".
However, for one of the 2024's I had two snapshots. And it's value changed from a "0" to a "1" earlier this year. So I pulled in refreshed data for the other XLT's that previously had a "0" and they are now "1" also! So they have all received an update this year that changed that value.
My feeling is that this was previously an unused bit but now Ford appears to be using it for something. That's why it's not documented in the spreadsheet I guess; it's a new parameter.
So if instructions say make a "0" an "8", then it really means "add 8 to the existing value". So you make your "1" a "9".
Naveen
Naveen
Thank you for looking out for me. I am currently investing time in capturing current values of my truck and what potential values i need to change.
Also looking at tutorials to understand how to take backup.
Naveen
Naveen
So what that means is that is if you want to add another option that says make a "0" an "8", then you need to add 1 (make it a "9").
Thank you Sir. Appreciate your help on this one.
Naveen
Naveen
This is interesting. I ordered below parts from www.fordpartspros.com. Apart from sitting on this for 3 days.. I called them today to check status, and they told me that apart from Assembly Bolt everything else i ordered doesn't fit F150 2023 Lightning XLT :-(.
ItemPart #QuantityAmountStatusETA
Wire Parking Distance Aid SeML3Z-15K867-NA1$152.06In Stock
Cruise Control SwitchML3Z-9C888-DA1$54.00In Stock
Fog Lamp Assembly BoltW720714-S450B4$40.52In Stock
Distance SensorML3Z-9E731-G1$510.23In Stock
As per them, Here are the correct one's =>
Part NumberPart NamePriceQuantity
ML3Z-9C888-BACruise Switch$54.001
W720714-S450BFog Lamp Assembly Bolt$10.134
NL3Z-15K867-GWire Harness$117.731
ML3Z-9E731-ESensor$398.071
Can anyone suggest if i ordered the right parts and which website/company to use for parts .?
B177y
Oly Pen, WA
2024 Pro ER Max Tow
They say it doesn't fit because your trim level/VIN doesn't have this option. You are adding something to the truck that is not supposed to be there.
Please read or at least skim the entire thread. I promise that almost all of your questions have been answered and will give you a much idea of what you are getting yourself into.
Naveen
Naveen
Thank you. Actually why Im confused is that they prescirbed the right ones also ..
Sorry I updated my original post with info above just now.
watts/up
23 Pro SR
I can't speak to the switch or harness because I opted to not install those but I used the sensor you tried to order and it works on my 2023. It looks like the harness part number is just yearly iterative version (M->N). Bolt is the same part number. What's interesting it that it looks like they're specifying an older versions of the switch and sensor, but maybe I'm not deciphering the model numbers correctly.
https://www.truckofmine.com/how-to-decode-ford-part-numbers/
You may want to get a second opinion on those suggestions.
Naveen
Naveen
I installed this mod on my 23' XLT and it works great ?
Hi Good Morning, "theblunden"
I'm trying to do the same for my XLT 2023 Lightning 311A trim.. I ordered below parts from www.fordpartspros.com. Apart from sitting on this for 3 days.. I called them today to check status, and they told me that apart from Assembly Bolt everything else i ordered doesn't fit F150 2023 Lightning XLT :-(.
Can you please let me know which one you ordered and from where? Will really appreciate your response on the same.
jdmackes
2023 F-150 Lightning Pro
I'm not sure on the cruise switch, as I swiched out the entire steering wheel so I could have a heated one, but the fog lamp assembly bolt is the same, the wire parking distance aid is the same, and the distance sensor is the same as my Pro. I would assume they don't know what they're talking about, or these are updated versions maybe.
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1758306722027-ym
theblunden
NC
2023 F150 Lightning XLT
I
I ordered everything from the first post from the same place listed in this post. They might be telling you that it doesn't fit because it's not supposed to be on an XLT if those are the same part numbers that you ordered.
https://www.f150lightningforum.com/...keep-alert-to-2022-f-150-lightning-xlt.14870/
Sensor Assembly: ML3Z-9E731-G
Mounting Bolts(3x): W720714S450B
Wiring Harness: ML3Z-15K867-NA (don't order)
Steering wheel buttons: ML3Z-9C888-D
You might want to look at the other wiring harness that somebody listed if it worked for them because I had to do some splicing on that one I wouldn't order that one again if I had to re-do it
Naveen
Naveen
I
Thank you. Any reliable online vendor I can order from?
Naveen
Naveen
Passenger Side -
Hello Friends, Good Morning
Can someone please spot check if my understanding regarding having the required wire on the passenger side are validated by pic above ?
I'm not able to take this connector out completely.
Any help much appreciated.
Thanks
Naveen
Naveen
Good morning everyone
Can someone please advise what value should be changed for this..
SCCM *Only if you swap the left hand steering wheel switch for the one that includes the follow distance change
724-03-01 03xx xxxx
I did order steering wheel switch for distance change..
This is for Lightning 2023 XLT 311A trim.
Thank you.
