Tire life
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
I’m surprised by the number of Lightning owners reporting short tire life. I am at 57K miles on the OEM Michelins (2023 Pro SR) and I’m confident I’ll get to 60K with margin to spare. I’ve rotated every 12K-15K miles and currently run the tires a couple PSI high.
Joe Dablock
Stewartstown Pa. 17363
I am at 47k miles and I feel comfortable driving them through the coming Pennsylvania winter. They are Goodyear. I am quite satisfied.
captcory
cory
sw florida
'23 FORD Lightning PRO, honda pilot
53,000 miles on michelin they are worn around the outer edges and need replaced. I can see cords on one. ouch. I will run higher pressures on the next set.
Deleted member 12322
Guest
My Hankooks are at about 36,000 miles and they’re in rough shape… fortunately we don’t get a ton of bad weather where I’m at so I’m hoping to scoop up a new pair when I see a good discount.
Ford F-150 Lightning Tire life IMG_1049
davehu
hot springs, AR
I have 20k miles and it looks like I'll be able to get another 10k. Tires are at 36psi... They are hannook
detansinn
United States
I am at 47k miles on my OE Grabber all season tires. Plenty of tread left. It's looking like they'll go to 60k miles.
I do a lot of road-tripping without any stoplight to stoplight shenanigans, which I suspect helps.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
I have been seeing 70k miles or more out of A/T tires on my F-250 and my cousins nearly identical F-250. So I would expect that much or more life out of the tires on the lighter F-150 Lightning.
If tires are wearing out prior to at least 50k on your truck, then you've got terrible alignment or a really poor type of tires on your truck.
I had 35k on my Grabbers when they got replaced due to a puncture. There was enough tread to at least go another 5k or so but I didn't want a large mismatch in tires so replaced them all.
Mcgyverrod
Rod
Santa Paula, CA
2023 F150 Lightning Lariat ER (Rec'd 7/13/23); 2026 Lexus NX PHEV
Retired x2
What are people's experience with the Lightning's tire life. I have 16,000 miles on mine and they are looking quite worn. I may be able to get through the New England winter, but I do not think they will make 25,000 miles. I am careful with the psi and do not pull any heavy weight other than the truck itself.
I made 27k on my original Hancook tires. I replaced with Michelin Defender 70k guaranteed miles. I don't think it will make it. I live in the mountains with lots of curved roads, they seem to be lasting the first 10k better than the Hancook.
RiqRod
Rick
2023 F-150 Lighting Lariat extended battery
Administration
50K on my OEM Goodyear! Want to go with 285/60/20, instead of the 275/60/20. Anyone have the larger tires on the stock 2023?
Mcgyverrod
Rod
Santa Paula, CA
Retired x2
The heavy Lightning is fine on level, smooth roads like freeways and my tires would have probably lasted 50K+ miles. I live in the mountains with curvy mountain roads which accommodate over 80% of my driving as I mostly stay local. As a result, I had to change at 20K miles when my tires wore to 7/32. My new Michelin Defenders are projected for 70K miles..... we'll see in about 50K more miles (or less)
Ralph
I have two homes, one in the Mojave Desert and the other in the rural hills of the Ozark Mountains. In both locations I am miles from the nearest paved road, and on my driveway alone (in the Ozarks) the truck has to negotiate a long, vertical trek up a difficult to maintain rocky, rutted surface after miles of twisting, climbing roadway from the nearest state highway route. And wherever it is, my Lightning frequently carries loads - trash, gravel, construction materials, gear, etc.
Look, I think it is fair to say everybody's mileage (literally) varies. And I am pleased with mine.
Jseis
Washington
Hard cornering will smooth the outer tread to nothing in well less than 30,000 miles. Ease up on the cornering and good for 40K plus. I didn’t ease up.. nearly stacked the truck up crossing an icy bridge with a slight jog left at the end of the bridge šŸ˜³šŸ˜¬šŸ™ˆā˜ .
Ford F-150 Lightning Tire life IMG_8786
