FordPass PPO menu this is new right?
SFsparkie
2023 F150 Lightning Lariat ER 01/23
I would not blindly add 2.
For 7DO-10-04 xxx* xxxx xx-- See this post and enable AECVP keeping your other options the same.
For example if 0,4,8,C then add 2
If 2,6,A,E then it is already enabled and don't add 2. If you do you then you'd end up disabling it and toggling RF.
Got it- I see the spread sheet for 7DO-10-04
dmd3home
Dan
Central Coast CA
2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
This is fantastic!!! Well, it's a start anyway. I was soooo disappointed after buying my truck that to use PPO I had to leave the truck ON the whole time (often overnight) and had to turn OFF everything possible trying to minimize wasted power. What an absolutely dumb design!!! I expected them to be better than this. I guess this was finally fixed in 2025, but what about us faithful early adopters??? Why are we left out? Now it appears (I don't have it yet) that there are some improvements.....if only seeing what's happening with PPO. Hopefully this progresses to actually being able to CONTROL PPO and run it without having to keep the truck running the whole time! Please Please Please!!
SFsparkie
Thank. Requested update. Have not yet done Forscan for advanced charging.
Andrewbens
Modesto
Lightning
Mechanic
The Unc
Brett
Coos Bay, OR
2023 F150 Lightning
Tech
^^ This ^^
SFsparkie
Any luck? I saw the public beta is available today as well.
Just finished updated to iOS 26.1 (23B5059e). FP 5.28.0 does not show PPO. Have not used Forscan for Advanced Charging yet.
flyin525
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
I’m really sorry it didnt show up for you. I can’t think of anything else I’ve done that would have made it appear.
SFsparkie
What’s this forscan for advanced charging?
I know next to nothing about it and have not tried the Forscan. There is a link earlier in this post inferring it may have something to do with FP having PPO.
flyin525
flyin525
Richard
Youngsville, NC
It’s not fully functional yet for earlier trucks but it alllows you to set the amperage and global settings for charging. For example you can set DC fast charging to stop at 80% or any unknown AC chargers to stop charging at whatever threshold you want. It also shows your current t charge rate and Amperage. In the center screen while charging.
Andrewbens
Modesto
Lightning
Mechanic
It’s not fully functional yet for earlier trucks but it alllows you to set the amperage and global settings for charging. For example you can set DC fast charging to stop at 80% or any unknown AC chargers to stop charging at whatever threshold you want. It allows your current t charge rate and Amperage. In the center screen while charging.
Wow, I think every car has this feature but Ford. This would be awesome to have
christooma
2023 F-150 Lightning XLT
It's a very common practice in software development to enable or disable features for a subset of users during testing using feature flags - which can be flipped server side. In these instances, the user doesn't do anything to trigger.
That’s very likely the case here. Ford have done this previously when rolling out new FP functionality.
SFsparkie
No problem—appreciate your contribution to the content. I will try to get Advanced Charging with Forscan and see if it affects FP.
hajalie24
2024 F-150 Lightning Lariat Antimatter Blue
I'm on Android so maybe it's phone OS dependent?
Funny thing when I started the truck, then looked at the PPOB app, it showed the system in an OFF status, which surprised me, for years this has always defaulted to ON with the cabin outlets being available. Funny that many members over the years have indicated they would like it to remain default OFF until a need arises, maybe a recent OTA brought us this easter egg?
I manually turned the system on, to show only cabin outlets available.
Then I turned on the Frunk & Bed outlets, showing status' as expected.
My 5.28.0 version 9/8 installed 9/18, does not present a view of Productivity Functions on the Vehicle tab.
I noticed this too recently but I think once you start driving it turns on.
