FordPass PPO menu this is new right?
Rtashiro
Ryan
Winnipeg, MB, Canada
F150 lightning lariat, Mustang MachE
I have a 23 lariat and just upgraded to the iOS public beta 2 went back into go and no change for me 😢
SFsparkie
2023 F150 Lightning Lariat ER 01/23
I would not blindly add 2.
For 7DO-10-04 xxx* xxxx xx-- See this post and enable AECVP keeping your other options the same.
For example if 0,4,8,C then add 2
If 2,6,A,E then it is already enabled and don't add 2. If you do you then you'd end up disabling it and toggling RF.
Got it- I see the spread sheet for 7DO-10-04
dmd3home
Dan
Central Coast CA
2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
This is fantastic!!! Well, it's a start anyway. I was soooo disappointed after buying my truck that to use PPO I had to leave the truck ON the whole time (often overnight) and had to turn OFF everything possible trying to minimize wasted power. What an absolutely dumb design!!! I expected them to be better than this. I guess this was finally fixed in 2025, but what about us faithful early adopters??? Why are we left out? Now it appears (I don't have it yet) that there are some improvements.....if only seeing what's happening with PPO. Hopefully this progresses to actually being able to CONTROL PPO and run it without having to keep the truck running the whole time! Please Please Please!!
SFsparkie
Thank. Requested update. Have not yet done Forscan for advanced charging.
Andrewbens
Modesto
Lightning
Mechanic
The Unc
Brett
Coos Bay, OR
2023 F150 Lightning
Tech
^^ This ^^
SFsparkie
Any luck? I saw the public beta is available today as well.
Just finished updated to iOS 26.1 (23B5059e). FP 5.28.0 does not show PPO. Have not used Forscan for Advanced Charging yet.
flyin525
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
I’m really sorry it didnt show up for you. I can’t think of anything else I’ve done that would have made it appear.
SFsparkie
What’s this forscan for advanced charging?
I know next to nothing about it and have not tried the Forscan. There is a link earlier in this post inferring it may have something to do with FP having PPO.
flyin525
flyin525
Richard
Youngsville, NC
It’s not fully functional yet for earlier trucks but it alllows you to set the amperage and global settings for charging. For example you can set DC fast charging to stop at 80% or any unknown AC chargers to stop charging at whatever threshold you want. It also shows your current t charge rate and Amperage. In the center screen while charging.
Andrewbens
Modesto
Lightning
Mechanic
It’s not fully functional yet for earlier trucks but it alllows you to set the amperage and global settings for charging. For example you can set DC fast charging to stop at 80% or any unknown AC chargers to stop charging at whatever threshold you want. It allows your current t charge rate and Amperage. In the center screen while charging.
Wow, I think every car has this feature but Ford. This would be awesome to have
christooma
2023 F-150 Lightning XLT
It's a very common practice in software development to enable or disable features for a subset of users during testing using feature flags - which can be flipped server side. In these instances, the user doesn't do anything to trigger.
That’s very likely the case here. Ford have done this previously when rolling out new FP functionality.
SFsparkie
No problem—appreciate your contribution to the content. I will try to get Advanced Charging with Forscan and see if it affects FP.
