Charging Lightning from a generator
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
An interesting exercise is to determine your gas mileage on the generator. Haven't done it on the Lightning yet but with my Niro PHEV my little 1500W Harbor Freight generator got 30 MPG.
jwrezz
1996 Ford Explorer, 2006 Subaru Outback Sedan, 2024 Ford F150 Lightning
Teacher/Firefighter
There is third option. Using the 120v dongle and a 240v source (would need a plug adapter) the Ford mobile charger will charge 240v at 12a (2.8kw).
Shouldn't the evse tell it's got the 120v dongle and only accept a suitable source? I'm sure there are plug adapters out there just as there are suicide cords for generator inlets, but I wouldn't think it would work.
richguy82
Richard
2023 Ford Lightning Lariat
I’ve been meaning to test my inverter generator with the Ford Mobile Connector. It has a NEMA 14-50 connection, but the running wattage is only 7200. I believe the connector only operates at 32 amps, but my gen can only manage 30. 🤔
mr.Magoo
2022 Lariat ER, AMB
This is kinda misleading, but you were speaking generally. 120v outlets (in the US) are capped at 20 amps, but most are 15 amps. 240v outlets can be 50 amps. So yes, a 4kw 240v split phase generator would most definitely get you more kw output to the truck than any 4kw 120v only generator, even if it had a 30 amp twist lock outlet.
True !
But A) I was trying to keep it simple and I general terms and considering the question was about a small generator I pictured something along the lines of 2000w. (Hence the question of "depends on what you consider small")
B) The dilemma is that a 4kW generator probably has a lower continuous load, say 3500W, so now you'll need a charger that you can de-rate as much, which most people don't have, especially those on the Ford Mobile charger.
RLXXI
3rd rock
Automotive Technician
True !
You can derate for the mobile charger on 2025 models on screen and in app . Before I got my FCSP installed I had to charge using my dryer outlet and had to drop it from 48A to 27A so it wouldn't trip the breaker.
mr.Magoo
2022 Lariat ER, AMB
That's interesting, would you mind sharing a screenshot/picture when you get a chance.
K6CCC
K6CCC
Glendora, Calif.
Good bet that would work.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
You plug a 120v anything into a 240v source and you'll let the smoke out, electronics works on smoke dontcha know.
The Ford mobile charger is configured to accept 240v. If it was only a 120v charger you'd get smoke.
The dongle just tells it what amps to set. It doesn't configure the voltage of the charger. The +- prongs of the 120v dongle are routed to the same pins as the ++ prongs of the 240v dongle.
Whatever adapter you use for the 120V to 240V receptacle is in the same category as suicide cords. Such adapters can be found on Amazon where any dum-dum can buy them.
This works on the Ford mobile charger.
PJnc284
Garner, NC
I wouldn't expect the efficiency to be very good. OP in the cwd thread below had a Duromax XP16000 (16kW peak, 13kW running) and 3 gallons added 18.92kWh in 2 hours. His 2.1mpg would give you about 13mpg.
https://www.f150lightningforum.com/...ge-extender-for-f-150-lightning-testing.30916
EverDrive - Charge While Driving a Ford Lightning
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
OP, you can use a propane generator and spare yourself the gasoline troubles. Propane does not go bad like gasoline will. Also the expensive ethanol free gas claims to be pretty long lasting. I have found a generator with an inverter to be more reliable in powering the Ford mobile charger.
K6CCC
K6CCC
Glendora, Calif.
That was largely not an option when I bought my Honda.
The inverter generators are far better in pretty much all respects.
jwrezz
Teacher/Firefighter
Ok so you've tried it? That seems to make sense, id think the dongle would tell the charger both amperage and voltage, but if it's dumb, I guess that'd be a cool way to double your watts if you had a small 240 volt outlet for a compressor or air-conditioner.
jwrezz
Teacher/Firefighter
I have a nema 1450 to L1430 adapter and my inverter generator only outputs 8750 peak 7200 constant. The ford adapter can take 32, but if the generator can't give it, the evse will take what it can get. I ran my generator for about an hour giving the truck 7kwh to the battery.
richguy82
Richard
Great to know. Thanks! 🙏
