Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Now that it has been verified to work, I've added to post 1. Thanks to Jesse and all the folks who tested it.
Enable Pro Power Onboard with truck off (2022-2023 only. Standard on 2024+).
Creates a Sync toggle in the Pro Power settings screen. See this post.
7D0-10-03 xxxx xx2x xx--
7D0-10-04 xxx* xxxx xx--
If 0, change to 8. If 4, change to C. If 6, change to E
If you enabled the Advanced Charging Screen, you likely have a 6.
Requires truck to have 2025 PCM update and likely Sync version 25094.
Well, just tried this on my 2022 LER and I get the ON/Off toggle, but it won't stay on. From what I can tell I should have the latest updates as it got BC 1.4 last month and several other updates mentioned by masses. My 7Do-10-04 was set to 4 & changed to C, only change I made.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
You need powertrain update that has not been released OTA yet.
when it comes out it will likely be the 10.3.0 OTA update
Karlos
Karl
DFW & Kerrville Tx
Got 10.3.0 back in Feb 2025:
Software Update 10.3.0
02/25/2025
Powertrain Software Updates
As a part of this update, you will notice:
• We’ve squashed some bugs that presented unnecessary warnings on your instrument panel
• Improved the electronic parking brake software for more consistent performance
• Increased the charging rate at DC fast chargers
Additionally, you may see an impact to your Charge Settings being removed including your charge preferences and pre-saved locations.
If you have NOT received the update, please take the following steps:
1. Unplug your vehicle during the scheduled update
2. Once you have received the update, reapply your charge settings via your in-vehicle settings
If you have received the update and were charging or notice your charge settings have been erased, please take the following steps:
1. Delete your vehicle from the FordPass app (this will remove your Phone as a Key)
2. Add your vehicle back to the FordPass app
3. Follow the Ford authorization / activation instructions
4. Re-apply your charge settings and any other connectivity feature settings that were lost
flyin525
Richard
Youngsville, NC
Hmm I figured 10.3 would cover it. There was a set of powertrain updates a few weeks ago. The ability to work seems to be based on the PCM.
I have the the same problem you have the PPO stay on switch won’t stay on. But I haven’t received 10.3.
Karlos
Karl
DFW & Kerrville Tx
The 2022 LER seems to have gotten all the updates out there over the last 10 months or so: BC 1.4, faster DCFC schedule and other bells & whistles. I've done the Glare-free, seatbelts, and all the Camera mods on Page 1, to both this truck and my 2023 LER. The 2023 LER hasn't gotten an OTA since March when BC 1.4 tried to load and failed. I have forgotten to put a trickle charger on it a couple of times when I leave it for 2-3 weeks at a time & come back to find the LVB at 45-65 SOC and figure that's part of the problem. I've finally found a trickle charger that works on the LVB - an aircraft GBM maintainier that will 13.5-14 volts and maintains it at 100 SOC
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
Perhaps dumb question...how do I know if I have the 10.3.0 update. Is that something forscan will tell me?
Mine does the same thing of not staying latched. I have rec'd most OTA's, BC 1.4, etc. as well. I did not get 10.3.0. The last time my PCM was updated was last November when the dealer did some CSP's (Charge Cord Stuck, Front Parking Sensors).
Mike G posted that a PCM update became available in FDRS in March - I think that's the one we need. There has since been another one recently.
Mike G
N. AL, USA
I'm currently on PCM software NL3A-14C204-BCZ as the latest from October.
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Is there a list of versions anywhere?
In looking at my database of 100+ VINs, the PCM module version varies quite a bit based on year and trim. So this may be difficult to compile especially since so many folks don't divulge the model year and trim in their signature or Account Details.
I know mine is out of date and it's NL3A-14C204-BBV. I have 3 2023 Lariat SR's in my database, all have different F188 values: PL3A-14C204-FS, PL3A-14C204-FP, PL3A-14C204-ER.
FORScan will allow you to see what software strategy the modules in your truck is on, but it won't tell you if that's the latest version or if there is a pending update for the module or not.
OMO7
23 Lightning
@bmwhitetx Any cause for concern about needing to put the 12V on a charger while doing 3-4 mods?
Seem likes the Glare Free could take 10-20 minutes alone.
PJnc284
Garner, NC
It shouldn't take more than a couple minutes. I haven't used a charger for any of the Forscan mods.
Perhaps.
That includes saving 5+ as built save files?
Will not be an issue. I typically use ACC mode and turn off the radio and HVAC just because they are distracting. But you could also do it with the truck on I suppose.
Take your time and make backups (they are very fast). One could do the glare free in under 5 minutes.
This isn't like FDRS where updates are done with the truck off and can take an hour or more.
