Rotary Shifter Part Numbers
Ronmard
‘24 F150 Lightning Flash
Avoid this seller. He’s advertising a different part number than being shipped
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_3147
Robocop
2022 Platinum; 1962 Lincoln Continental
Just a tip for others,
I recommend finding a good, cheap unit by checking with local salvage yards, you-pull-it or other parts recyclers local to you, not necessarily ebay. The source parts from certain models are truly mass-produced, dime-a-dozen so the spare parts should be plentiful and easy to find for cheap in good-used condition. I got a used one, so it smelled a bit weird and was pretty dirty when it arrived, but it is now clean it looks amazing and it works!
Keanen
Keanen
MN
2023 F-150 Lightning
Software Engineering
Same here. Insert on the way and still trying to sift through this thread to determine the best one to buy. Will most likely get an OEM rotary shifter from ford as most of the eBay links are sold or no longer listed.
Did you find a dial that worked for you and if so, could you share the link please? Thank you!
chapba
mike
2024 Flash
fire
@Keanen i wish i had a good update bud but I took a chance and ordered one off of eBay and got a JX6P instead of a LX6P that they had advertised. Another forum member got the same model and it threw a bunch of codes so I didn’t even bother installing. Guess I will have to get an OEM like I thought I should have in the first place 🥲
mrkwtech
Tampa Bay, FL
peoplenotproperties.com
2023 Platinum
Real Estate
KennyB123
Ken
Detroit, MI
Also got duped on the wrong part, didn't notice until after the truck rejected it. The ebay seller is allowing a full refund even after knowing I dremeled off a bit of plastic so the part fit the 3d printed shell. I can't complain about that. Just ordered the same shifter as @T3Fan from my local ford dealer. Had 50 bucks in points thanks to getting new Michelin Defenders a couple weeks ago.
chapba
mike
2024 Flash
fire
They are selling PZ1P-7P155-AC as LX6Z-7P155-U. If you want a non motorized one, you are good. But you won't get the LX6Z-7P155-U from them.
Hey man I made the mistake of ordering this one from the multisurplus guy as well before re-reading this thread again. So the errors you experienced with this trying to shift to park on the highway weren’t caused by this shifter? Just making sure it’s good to go. They advertise it as the correct part now instead of the L version.
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
The PZ1P works fine. My errors were unrelated. The only note now is that it is non motorized.
chapba
mike
2024 Flash
fire
Ok cool I saw in the spreadsheet (after ordering) to not order from multisurplus and was hoping it was just for false advertising. I would prefer the motorized but not a deal breaker for me.
mrkwtech
Tampa Bay, FL
2023 Platinum
Real Estate
I'm officially ordering one directly from a Ford dealership, and the specific part number is already on the verified list thanks to @T3Fan . I think getting a brand new OEM one is totally worth the peace of mind, given I own a nearly $100k truck lol.
https://parts.lakelandford.com/p/109202692/LX6Z7P155X.html
So interestingly enough, I was a bit surprised to open the LX6Z-7P155-X box at the dealership parts counter and find a different part number inside lol. It appeared to be a brand new factory sealed box, so the parts guy said they do that sometimes hmm. I verified the LX6P-7P155-LE part number via this thread, so I took it home and gave it go. I've now confirmed for myself that it's both motorized AND lit up via ambient lighting ring at the bottom. I think I've gotten out of the truck with it still in gear at least once daily since installing, just to satisfyingly watch it turn back towards park haha.
On a side note, add another happy @PolymerBuilt insert user here as well.
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0039
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0041
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0051
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0073
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0074
ctofan
2023 Platinum
mxracer
Dan
2024 F-150 Lightning Flash
I can verify this one works from ebay.
It is not OEM and is listed as a PZ1P-7P155-AC but works fine without any issues and has been in my truck for a few weeks now.
Mike G
N. AL, USA
That's exactly the same one I got, the -LE, and it works perfectly. I love the Bronco Sport rubberized ring and the little blue ambient light at night.
No error codes or DTCs ever from day one.
tatanka
Southern California
'22 F150 Lightning Lariat SR
Were you able to get 155-X installed, and if so, did you have to make any modifications to the part?
Thank you to all the contributors on this thread. I used the LX6Z-7P155-X shifter. Zero issues with install or recognition by the Lightning (no error codes). I did not need to make any modifications to the part. Rotary shifter works perfectly. The rubberized ring, motorized feature, and ambient light at night are nice touches!
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_0831
Robocop
I ordered a second version from the original supplier of these Manion Makes after he introduced a "finless" version of the binnacle, which I much prefer.
Taking inspiration from the OP, I hit mine with a few coats of sandable primer, then matte black paint, then matte clear with plenty of sanding along the way. This looks closer to factory than my first attempt using a satin clear to finish, which was much too glossy.
I wanted it to turn out nice and not look rough and unfinished. I am no painter by any means but I took my time and I'm pretty happy with the result.
Ford F-150 Lightning Rotary Shifter Part Numbers Image (1)
