Pitbull2o08
It’s wild we are still operating on faulty equipment 3 years later.And Another video to add to the list:
The weak link is most certainly this unit - although it's not made by Ford. It's made by Siemens.From this latest video it seems the weak link in the chain is ford EVSE wall unit.
I'm surprised the bean counters at Ford haven't told the executives "either fix it, or buy them back, because a lawsuit is the most expensive option."It’s wild we are still operating on faulty equipment 3 years later.
Talk of any lawsuit seems to have totaled been silenced. Without any inside knowledge, I’ld wager that Ford has contacted the disgruntled users and bought them off.I'm surprised the bean counters at Ford haven't told the executives "either fix it, or buy them back, because a lawsuit is the most expensive option."
Thanks, I didn't think of that.Talk of any lawsuit seems to have totaled been silenced. Without any inside knowledge, I’ld wager that Ford has contacted the disgruntled users and bought them off.
One day this thread was hot as a firecracker and the next day it was over.
Just a SWAG on my part.
Would be great if you could find out what updates were installed and let us know. Congrats on finally getting your system to work as it should!The tech installed 3 updates that did update many of my truck systems on 11/10.
I knew others would ask, so I asked the tech which updates he performed but all he was able to provide were 3 pages of systems showing they were updated. I have a strong suspicion that ECG2-25.2.8.5 might have been the most pertinent update but he did install 2 others as well.Would be great if you could find out what updates were installed and let us know. Congrats on finally getting your system to work as it should!
Yah, @Ford Motor Company What company could do that?Ford let me down again. My Home Integration System worked for 3 tests only. Shortly afterward, we had a power failure and the system didn't work. I had to use the charge cord trick for power transfer.
The very next day, I tested the system again. System was inoperative. Fault errors at the inverter and the Ford Pro charger. What an extreme disappointment. What other company could get away with selling you an expensive product that does not work as advertised with absolutely zero customer service or resolution.
I know how you feel. I had my Ford Home Integration System professionally installed in October 2023. I was so excited. I was there when my electrician tried it out for the first time and it worked perfectly. A month later when the first outage occurred it failed. I was disappointed but figured that Ford would be right on it. After all, (I thought), they had committed a very large advertsiing budget for advertising and there was no way that they would do anything other than do whatever it takes to make this product a big success. Well, I was wrong. Like many of us, I spent countless hours on the phone to the BEV Group and anyone else at Ford that I thought would help. I tried everything that they advised. Fast forward to now and so far I have been able to get it to work with the work-arounds but needless to say, it doesn't operate as advertised. It has been a huge disappointment and the most frustrating experience that I have had with any product in my 70 yearsFord let me down again. My Home Integration System worked for 3 tests only. Shortly afterward, we had a power failure and the system didn't work. I had to use the charge cord trick for power transfer.
You mean those same Siemens units that are having issues when using charging times and departure times? The worst part is Ford is fully aware and doing nothing.It frustrates me that the GM system makes use of pretty much the same gear and people don't seem to be having the same issues. The only thing different? The charging station IIRC.
It's almost like @Ford Motor Company needs to either open it up or replace the Siemens units.
