Unlock truck from charge port?
hb.sagen
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Does your truck not have the sensor on the door handle to unlock by touching it? My 23 XLT does, so I would have thought the Lariat would. But I am not at all familiar with European spec
Yes it does. But I can’t reach the passenger door in the garage. So I have to walk around the car and back.
I <3 My Lightning
*counts the days before someone sources parts to do US dual side charging option*
Henning has been helpful with my quest to get my charging port moved to the other side. I am not after dual ports, just more convenience for me, for DC charging. The provided pictures are from Henning.
I just have not been able to source the charging port shroud/surround/door, it's a perfectly manufactured mirror image of ours. I have the proper fender and port door cover on my '23.
Ford F-150 Lightning Unlock truck from charge port? Screenshot_20251119-061107-049
Ford F-150 Lightning Unlock truck from charge port? Screenshot_20251119-061201-888
Adventureboy
I don't think this is an easy fix for the OP since the lock mechanism is connected to the door lock system on the truck and the pocketed keyfob/PAAK requires a touch sensor to unlock, which the port does not have.
To my knowledge, Forscan options have not been found for either enabling (for NA) or disabling (for EU) the port L2 lock feature. Perhaps the experts will find a way someday, as I'd like to enable the feature on my NA truck.
@Ford Motor Company might be able to change it programmatically, by changing the port lock to operate on the proximity system similar to the Frunk and tailgate, but it probably wouldn't be high on their list. I'd suggest putting in a request using the "Give Feedback" option on the Ford App.
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
As an experiment, without unlocking the vehicle, if you place the fob on the left side of the vehicle (base of the windshield, for example), and then walk back to the right side and try pushing the unlock button on the port, does it unlock? Off hand I'm not sure if the EU versions have approach detection for the port unlock at all.
hb.sagen
hb.sagen
Henning
Norway
I will test this.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), 2023 F150 Lariat ER
Sounds like the best option in the US is to put the NACS plug in the 'right hand charger door' location! Then we can charge with the FCSP in the garage, and at a Tesla Destination or Fast charger on the road! How much will that cost?
Of course we would need some software updates to recognize if you have plugged a charger into both sides to tell you to knock it off. Or maybe for my 2023 use the primary charger for one side and the secondary charger for the other side :crazy:
MidAtlanticLightningClub
F-150 Lightning Lariat ER
There is limited space in my garage, and my charge port is on the right side of the vehicle, and that's the side I enter the garage.
To unplug the charge cable I either have to walk around the truck and unlock the car with the driver door, or fish out my key and press the button. I loose at least 4 seconds every day doing this. Passenger side is inaccessible.
Why can't the car unlock the charge cable when I press the button, keeping the key in my pocket? Why do I need to unlock the doors first?
Can this be changed with Forscan?
Do you have a setting to turn off the cable lock? I would look in the vehicle settings menu.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
Back into the garage instead?
Perry
Perry
2925 F-150 Lightning Lariat
That ^^^^
would be very handy at the Tesla charging stations..hear that Ford? lol.
I saw a 2022 with the charge door on both sides and thought - wait did they have charging on both sides in 2022 and then cut that in 2024...nope.
Sure, but once we had charging ports on both sides, we’d want to use them both at the same time to double the charging speed… 😀
Robert
NW Ontario Canada
Contractor
Great Idea - and really piss off other EV's that not only does it look like we are blocking two chargers with the darn short power cords at Tesla charge stations, we actually ARE using two chargers !
LOL - but honestly wouldn't it be handy if there really were a charge port on each side - pluggin in one automatically disables the other with an interlock?
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
This is an aftermarket upgrade I'd pay for, if someone was willing to go through the process of developing a kit.
It's clearly easier on pre-'24 models, where we have a blanking plate on the opposite side to the factory port...
Maineiac12
Iowa
It would be nice if my charge port would lock. Wonder why that’s not a standard feature?
Mach-E got that as an update recently. Maybe soon.
digitaldad
ABQ
'23 Lariat ER MaxTow
Is the hole cutout the exact same as the drivers side? I've pulled off the "blank" right side before and if it could contain a right-hand side OEM door/hinge, I think I would fab a FDRS/jump point/battery tender mod there.
