K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
I don't have specific information, but I don't believe that is correct. If you plug into a Tesla (or any other Plug and Charge location), all you have to do is plug in and charging will start - no app required in most cases (some do). The vehicle has to tell the charger who you are so that the charger can know who to bill. With your thought that only the manufacturer is sent, then Ford would not know who to bill. The vehicle must identify itself - and the VIN is the logical identification to use.There is also nothing to say that any other vin-specific information is provided to Tesla, or others, when you initiate a charge thru the FORD App, or any other way. In that case, that vendor is sending the charge activation to Tesla.
If you use the Tesla app, yes, you may be providing that full vin IF you have given it to them, which may be a requirement when you create your profile, of course.
As I said, some chargers that are Plug and Charge for Fords require activation from an app prior to unlocking the charging cable from the charger, or before starting the charge. That might be the Ford app or the charger network app. My sample size is small as I have used Tesla SuperChargers only three times without a Tesla subscription prior to installing 240V charging at home. I just plugged in and charging started and was billed to the Plug and Charge saved credit card. Since that time any time I charged at Tesla or EA, I had a membership and used their app prior to plugging in. I have also used EVGo once, BP Pulse once, and PowerFlex quite a few times and all used their own app to start (none of those are Plug and Charge).
