MattVT
Matt
Vermont
2025 F-150 Lightning Lariat
One of my grievances about new cars is how many things are moving to apps which require cloud access and often subscriptions to use them. When we bought our Subaru Crosstrek a couple of years ago, we paid an extra $400 to have the dealer install the OEM remote start module so we could use our factory key instead of the app.
When I bought my 2025 Lightning in September this year, I was pretty disappointed to see that remote start was once again an app-only feature. Here in Vermont, being able to pre-warm the vehicle is incredibly valuable during our long, cold winters. And unfortunately, where we live we have very poor cellular signal for whichever carrier the vehicle's modem is using, so the app experience is very poor. Using the app for anything that requires a vehicle connection (e.g. remote start, configuring departure times, etc) is at best hit-or-miss - sometimes it works fine, but often it will repeatedly time-out and fail.
While I can (and do) schedule departure times for regular journeys (e.g. my morning commute), doing this for one-off journeys is a painful experience. With my previous F-150, I'd just click the key fob a couple of times 10 minutes before I wanted to go out, and that was that.
We have an extensive home automation system in the new house we're building, and integrating the truck into that was a priority for me. From research on this forum and elsewhere, I decided to buy a new key fob from North Coast Keyless for about $90 which did have the remote start feature, then wire this up to an ESP32 giving me control via Home Assistant (our home automation system).
The key was out of stock for a while, but a couple of weeks ago I checked and it was in stock, so I bought it and it arrived a few days later. I programmed the key myself using my 2 existing factory keys which only took a couple of minutes following the instructions in the owner's manual.
Then I tore the key apart. I had hoped that like other key fobs, it would simply clip together, but as best I can tell it was actually glued shut, so I ended up cutting and prying it open, taking care not to damage the PCB inside.
With my digital multimeter, I confirmed the behavior of the 5 small SMD buttons. Opposite pairs of legs are electrically coupled, with one pair tied to ground. So pressing the button simply pulls the other two legs to ground. All the buttons are oriented identically and work exactly the same way.
From there, it was simply a case of soldering wires onto one of the output pins on each button. I'm not the best at soldering, and these pins are tiny. 4 out of the 5 buttons were easy, but the remote start one by the chip was trickier to get to and I ended up prying off the button top to make things a little easier. I soldered a short female DuPont wire to each button, as well as to the positive and negative battery terminals on the other side of the board. I bought a small, angled soldering iron tip for my Pinecil just for this, and liberally applied solder flux. It's not the neatest job, but my DMM confirmed I had connections.
Ford F-150 Lightning Local Home Assistant integration via ESPHome and key fob IMG_8558
Ford F-150 Lightning Local Home Assistant integration via ESPHome and key fob IMG_8559
I used the female DuPont wires as they were what I had on hand and in future I may do something a little cleaner using a proper connector. For now, I simply connected them to a $7 M5Stack AtomS3 Lite I had lying around which has an ESP32-S3 and just enough exposed GPIO pins for my use case.
I programmed it with ESPHome, and my config is below in case anyone is interested. I'm sure this could be cleaned up and improved, but for now it works. The basic approach is that it exposes a virtual button to Home Assistant for each of the key fob functions. Pressing the button in Home Assistant pulls the GPIO to ground for 500ms, then lets it float again.
Ford F-150 Lightning Local Home Assistant integration via ESPHome and key fob IMG_8560
For the tailgate open / close button, I trigger it twice from one press in Home Assistant as that's what the remote requires. For the remote start, it "presses" the lock button twice, then the remote start button. I also exposed the remote start button directly so you can turn the vehicle off after it's been remote started.
Power is only sent to the key fob just before each key press, and turned off shortly after the key press has finished. I think I'm giving it enough time to maintain synchronization, but I'll report back if I run into issues. I could probably just keep the key powered on, but from a safety and security perspective I felt like only powering it on when needed is best. Also, technically the coin cell battery was delivering ~3.0V and I'm giving it 3.3V, so keeping it disconnected except when needed seems to make sense.
I've tested it and it all works exactly as expected. Unfortunately, there's no feedback other than looking at the truck to see if it worked. While the key fob fascia makes it look like it has an LED (and I swear my old truck key did), there's no LED on the actual circuit board. I was thinking of tapping into this as a feedback loop of sorts.
For now though, being able to remote start the truck from Home Assistant is huge. I can expose this feature through any number of means now - the LocalDeck by our front door, voice control, a button in Home Assistant, etc. I can also schedule it or integrate it into other scripts.
I've also done some other related "mods" too. I have a couple of automations which remind me to plug the truck in if it isn't already (using connection status from our EVSE) - it reminds me 10 minutes after I get home, or at 9:15pm each evening, but only if the truck is home.
I know this isn't new or novel and plenty of people have done this before, but I didn't see much mention of it on this forum so thought I'd share, if nothing else to confirm that it works with a 2025 Lightning Lariat.
Here's my ESPHome config for anyone interested.
YAML:
esphome:
  friendly_name: Ford F-150 Lightning Key
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: esp-idf
logger:
  level: DEBUG
api:
  encryption:
    key: [REDACTED]
ota:
  - platform: esphome
    password: [REDACTED]
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
switch:
  - platform: gpio
    pin:
      number: 38
      mode: OUTPUT
      inverted: false
    restore_mode: ALWAYS_OFF
    internal: true
  - platform: gpio
    pin:
      number: 5 # green
      mode: OUTPUT_OPEN_DRAIN
      inverted: true
    internal: true
  - platform: gpio
    pin:
      number: 6 # yellow
      inverted: true
    internal: true
  - platform: gpio
    pin:
      number: 7 # orange
      inverted: true
    internal: true
  - platform: gpio
    pin:
      number: 8 # white
      inverted: true
    internal: true
  - platform: gpio
    pin:
      number: 39 # brown / blue
      inverted: true
    internal: true
button:
  - platform: template
    icon: "mdi:lock-open-variant"
    on_press:
      - switch.turn_on: fob_power
      - delay: 500ms
      - switch.turn_on: gpio_unlock
      - delay: 500ms
      - switch.turn_off: gpio_unlock
      - delay: 500ms
      - switch.turn_off: fob_power
    icon: "mdi:lock"
    on_press:
      - delay: 500ms
      - switch.turn_on: gpio_lock
      - delay: 500ms
      - switch.turn_off: gpio_lock
      - delay: 500ms
    icon: "mdi:refresh-auto"
    on_press:
      - delay: 500ms
      - delay: 500ms
      - delay: 500ms
      - switch.turn_on: gpio_start
      - delay: 500ms
      - switch.turn_off: gpio_start
      - delay: 500ms
      - delay: 500ms
      - delay: 500ms
    name: "Remote Start Button"
    icon: mdi:refresh
    on_press:
      - delay: 500ms
      - delay: 500ms
      - delay: 500ms
    icon: "mdi:bullhorn"
    on_press:
      - delay: 500ms
      - switch.turn_on: gpio_vehicle_alarm
      - delay: 500ms
      - switch.turn_off: gpio_vehicle_alarm
      - delay: 500ms
    icon: "mdi:truck"
    on_press:
      - delay: 500ms
      - switch.turn_on: gpio_tailgate
      - delay: 500ms
      - switch.turn_off: gpio_tailgate
      - delay: 500ms
      - delay: 500ms
      - delay: 500ms
B177y
Olympic Peninsula, WA
I love seeing stuff like this!
The programming part is out of my comfort zone, but tinkering with the key fob is giving me some interesting ideas.
I also purchased a 3rd fob with the start button but I do miss the ability to open the frunk with that fob. Is it possible to add the frunk opening without sacrificing another fob? Also, if you can point me towards a link with your automation program, I'd love to learn more about how that works.
MattVT
Matt
Vermont
Not without a totally different approach. The way I'm doing it is that my little ESP device is just emulating a button press. If the button doesn't exist, there's nothing for it to "press". It is a little annoying there being no frunk control - I'd rather have that than tailgate - but I guess at the very least I can do that from my regular key.
The only ways I can think of to do it are:
  1. Buy another key fob with the frunk control, and wire it up in a similar way to this one. That would be another $90 just for that feature, but technically I can have 4 key fobs for the truck so it would theoretically work
  2. Reverse engineer the key fob and see if I can work out how each button press is turned into a signal by the fob. If I had to guess, there's probably a pin somewhere on the PCB that you could pull to ground and emulate a frunk button press, but I don't really have the tools for that type of tiny tracing. Not to mention then trying to solder to that.
I use Home Assistant as the overarching home automation system, and ESPHome is the specific firmware I'm running on the Atom S3Lite device in the pictures. I've been running Home Assistant for years and it is the hub for all our home automation. Unlike things like Alexa, Google Home, etc, it all runs locally on a server in our house - there's no cloud dependency, no company to one day shut off / charge for access, and none of my data is being sold. The flip side is that I have to manage it all myself - a trade I'm happy to make.
fhteagle
D
'22 Lightning Lariat, '23 MYLR, '13 Forester, sold '13 Volt
Great idea and write up.
Anyone have any idea if a remote start fob would actually begin HVAC and/or battery warming on a '22? It's about to get cold for real up here in the mountains and I'm sure I'm going to miss warming everything from wall power, as I had with my previous vehicles.......
25StarWhiteLightning
Midwest
2025 Star White Lightning Lariat
Why not just use the Fordpass custom integration in HACS? Besides tailgate control, I think it gives all of these features and more.
MattVT
Matt
Vermont
I do use the FordPass integration in Home Assistant, and it's great! But it still just uses the exact same API that the Ford App uses, meaning that if the truck is struggling with cellular signal, like it often does for me at home, the request to start never makes it to the truck so it fails.
Ford also has a poor reputation for allowing / supporting their API with 3rd parties, and there's always a chance it might suddenly disappear - this insulates me against that risk.
Interesting and kudos for the accomplishment!
AT&T (the cell carrier if I am not mistaken) is also sometimes weak in our neighborhood, often can't get it indoors like when a vehicle is in the garage (my 2012 Nissan Leaf also used AT&T for communications, I say "used" because it was 2G and that is no longer supported by AT&T).
I wonder if you considered a cell signal booster for the Lightning, and if so, why did you decide against that? Such as the weboost Drive Reach OTR (link below)?
From the Q&A:
Q: My truck(2020 gmc 3500hd) has a built in cellular and wifi system. will the trucks system pick up the weboost to run better in low signal areas?
A: Hi there! Depending on what the truck's cellular system is working on, it may work. Our boosters are designed to work with all US/Canadian cell carriers.
Q: Does this boost your data connections and speeds?
A: This device is made to boost both voice and data, but data has some uncontrollable factors like amounts of users on the tower, data capacity, bandwidth, and others that effect it before a booster picks it up. In many cases, the booster will bring in the data speeds that are outside.
Review by alvin evans in the United States on July 5, 2024
My carrier is AT&T and if you have them, then you already know they have been on the decline in terms of celluar signal or data signal, I tavel out of the DFW area to the west coast and to the east cost. signal is terrible. that dreaded 4 dots or sos displaying on the phone is a bummer, i know. well Ive traveled to new york and as far as california testing this product. I can gauurantee this weboost booster is a life changer. I can honestly say I lost signal once and that was on I10 comming and going down that mountain before you get to desert springs in California. I was able to maintain signal for calls and netflix, youtube and spotify worked great. If your are a traveler I have to reccomend this weboost to you. I was about to spend over $1k on a new phone before this purchase and i am glad i tried this out first since you have 30 days to try it. Kinda pricey but well worth it.
https://www.amazon.com/weBoost-477154-Booster-Networks-Carriers/dp/B08WYQND57?ref_=nav_signin&th=1
This is a CONSUMER device. Before use, you must register this device with your wireless provider and have your provider’s consent. Most wireless providers consent to the use of signal boosters. AT&T, Sprint, T-Mobile, Verizon and 90 additional carriers have already given consent for all consumers to use this device. Some providers may not consent to the use of this device on their network. If you are unsure, contact your provider. You MUST operate this device with approved antennas and cables as specified by the manufacturer. Antennas MUST be installed at least 20 cm (8 inches) from any person. You MUST cease operating this device immediately if requested by the FCC or a licensed wireless service provider. WARNING. E911 location information may not be provided or may be inaccurate for calls served by using this device. Please note, the four largest carriers, namely, AT&T, T-Mobile, Verizon and Sprint, and more than 90 regional carriers have given a blanket consent to all boosters meeting the new certification standards. "
I wonder if folks who don't have the home assistant capability like you did could maybe use the weboost or something like it if they are in a weak cell zone?
If anyone has used the weboost and has tested it with the Lightning functions through FordPass (now just "Ford") app, let us now how it worked for you.
Related video:
MattVT
Matt
Vermont
The short answer is "no, I didn't", and honestly mainly because I didn't think of it! I love that you suggest it though, thank you!
Thinking about it now though, while it's a very interesting idea, I wouldn't do it. That said, I think for some people it could be a very good option, so I don't want to dismiss it as a "bad idea" - just not for me.
I really don't like the trend of smart devices (within which I'd probably include a lot of modern vehicles) increasingly locking features inside their own walled gardens, usually only accessible via proprietary APIs or apps, and often requiring a subscription. Customers are rarely given any guarantees as to the longevity of their access, the safety of their data, or the price of usage.
This isn't just a hypothetical risk, but very real - there are countless examples of this from the Bosch dishwasher that only allows certain features and cycles to be used from the app, to the Nissan Leaf app being deprecated for 8 year-old vehicles. And literally thousands more examples.
For me, remote start is one of those integral features that is inherent in the value of the vehicle. If that some day disappeared, the vehicle would be less valuable to me as a result. That's why with our Subaru Crosstrek, we insisted on the key-fob remote start instead of the app - for $400 one-off, we locked in that feature so it could never be taken away (or, as Subaru actually does, locks it behind a subscription that gets significantly more expensive after 3 years of ownership).
In my ideal world, I'd never have to open a manufacturer's app on my phone to manage a device. Sadly that's not always possible, but I always consider it a detractor when choosing what to buy.
I realize this is a very philosophical perspective, and one that I'm sure many don't agree with or perhaps even care about. And maybe for them, the idea of the cellular booster is a far more appealing option - that's awesome, I have nothing against that, and options for consumers are great!
But since I have the skills to do it, the existing home automation system in place, and the use case, I prefer my local-only, "you'll never take this away from me", solution to remote starting my truck.
PS - for what it's worth, my ideal solution would be a well-documented, secure API, that could be accessed directly on the truck (e.g. via WiFi) that would allow 3rd party developers to integrate with it directly. I totally understand the challenges associated with doing this on a vehicle (power consumption, security, safety, liability, etc) but that feature-set would genuinely be something that would factor very positively in my vehicle purchasing decision. We're already using this test for any appliances, devices and electronics we buy for our new home - unfortunately the EV market isn't mature enough for this to be a viable purchasing decider for us just yet.
PPS - just to reiterate what I said earlier, the FordPass integration for Home Assistant (which does use Ford's API) is fantastic, and the developer is doing an incredible job of keeping it working in the face of moving goal-posts as Ford changes its API with little concern for 3rd party developers. I donated to support that project a couple of weeks ago, and if you use that integration, please consider doing the same. And if anyone from Ford is reading this, please think seriously about the value of supporting a volunteer community developing against your product, building features, promoting its capabilities and adding value for customers - it's not all risk and liability!
Agree with all of the above.
I have a 2012 Nissan Leaf bought in Dec 2011, the app was great at first but then AT&T discontinued 2Gin 2017, so Nissan offered an upgrade to 3G...of course then AT&T discontinued that in 2022. Now I never really needed the remote start etc., it sits in my unheated garage which is through 1 door from the kitchen, and we don't often have polar level temperatures here. But I do miss the CarWings driving data I guess, though after 5 years of it, I knew what the Leaf was about - 4.8mi/kwh. And I can get in the vehicle and see the data, just can't save it directly to my computer.
Ford F-150 Lightning Local Home Assistant integration via ESPHome and key fob 2012 Display of Driving Records Elect Consumption
For it's time, 2011+, it was a good app.
A couple years ago Virginia started a Mileage Choice program which bases the "EV road tax" on actual miles driven, and it uses a cell connected reporting system to track mileage (GPS) and driving style (eg speed) - yes AT&T so if in the garage, no signal and the Mileage Choice system sends me an email asking if my device is still working. So I can get some data to my PC from that if I want it.
So far no issues with the Lightning and FordPass connectivity. Blue tooth streaming music never worked well though so I use the data USB with a SSD loaded with music and formatted in xfat - darn Ford for not keeping compatibility with the iPod format in the Lightning!
I can use an FM transmitter (an old iTrip) with the iPod and my Zune, as well as with a portable XM (Roady) but it's a bit of spaghetti with all the wire required - I have a Pro so no OEM XM capability - an upgraded box would be about $500.
The Leaf came compatible with the iPod and with XM built in standard. Whatever...
ipod and zune, holy old tech batman lol. I loved my ipod, 20+ years ago. The only thing apple made that I actually liked.
Old tech yep, but still doing the job - I'm getting pretty old myself, lol.
A lot easier to carry around the iPod or Zune than 400+ CDs and a walkman, for example.
And a lot less expensive than an iPhoey!
My iPod still gets some use in the Leaf - yes, I am not fond of iTunes software - doesn't play nice with Windows...but I managed to get my burned CDs on there somehow, took a while, and at first there were two of every song! Fixed that but that also ran overnight while I slept - so slow!
I actually have two Zunes, the original 30Gb model and the later 120Gb model.
I had them both upgraded a few years ago to 128Gb SSD and new batteries.
Both still work fine with my stereos here and in the house I inherited on Montserrat.
But an SSD (or thumb drive) formatted in xfat works with the Lightning Pro Sync 4 system through the data USB...a little hard to navigate the menu with so many full CD albums on there, so I often just put it on shuffle or run it with song names from A to Z.
I like musical surprises sometimes. And the XM channels/DJs get a bit repetitive, as does FM.
So let's just say I'm old enough to know better, but young enough to try anyway!
RipInPepz
Erik
Ohio
2025 Flash Antimatter Blue - 131kWh ER, 9.6kW PPOB
Just want to say, this is absolutely excellent work. I have poor AT&T coverage at my house too, so it take like 15 seconds for things in the app to actually happen. I may consider this.
MattVT
Matt
Vermont
I swear mine has got worse. The other day I tried multiple times over the course of several hours to update departure times and charging schedule in the app and it just kept timing out. In the end I gave up and went and sat in the truck to do it manually on the screen.
What I don’t understand is what exactly the truck uses WiFi for. I’ve given it WiFi credentials for my network but I see no traffic whatsoever from it - DNS or otherwise. So what’s the point of the WiFi? Am I missing something?
Reactions: chl
Good question...
I know it uses the wifi for the "hot spot" feature - then it connects the wifi hot sport to the cell network anyway, go figure!
Well, Ford also says this:
Is Wi-Fi required for over-the-air software updates?
No, Wi-Fi is not required, but we encourage you to use Wi-Fi if you can. Similar to updating your cell phone software, using Wi-Fi to update your vehicle software will help ensure a faster download and more seamless update process. But you can also use a cellular connection.  
Is Wi-Fi required for Ford Connected Services? 
No, Wi-Fi is not required to activate your modem or use Connected Services. After you download FordPass, you can connect your phone to your Ford using just your app-based smartphone, and your cellular service data plan. Message and data rates may apply. If you are having trouble activating your modem, contact your local dealer for support or call 800.392.3673. 
https://www.ford.com/technology/con...but we,you can also use a cellular connection.
So anyone out there ever use the wifi for OTA updates?
Would it be a truck wifi to cell connection anyway?
Call me puzzled.
RipInPepz
Erik
Ohio
I agree totally. My truck is parked very close to my router with a gigabit connection. But it feels like it never uses my WiFi or else the commands in the app wouldn’t take forever to execute.
