Remove full view not available and camera on signal?
kvasiir
San Jose, CA
2022 F-150 Lightning Lariat Rapid Red
EdRudy
Ed
Springfield, VA
Sorry if this has been answered already, I did a search and couldn't find it...
Does anyone know why I have the thick white lines in forward view when I enabled my at speed camera? Anyone know how to fix it?
Ford F-150 Lightning Remove full view not available and camera on signal? image0 (1)
PJnc284
Garner, NC
What values did you change? That looks like rock crawl mode so probably something related in the IPMA and APIM.
EdRudy
Ed
Springfield, VA
I may have changed to this value:
I'm not sure what the original value should be. I think xxxx xx00 xx--. Can anyone confirm?
Enable OffRoad (Rock Crawl, Mud/Ruts, and Deep Snow/Sand) Front Camera at SpeedIPMA706-02-02xxxxxx03xx--
PJnc284
Garner, NC
For 706-02-02, E47F-CE00 were the factory values on my 23 lariat.
EdRudy
Ed
Springfield, VA
Thanks, I'll give it a try.
That did the trick! No more rock crawling camera mode.
TrojanThor
2025 F150 Lightning Flash, Genesis GV60 Advanced
The only way is to plug something into trailer connection that draws enough power to make the truck think it has a trailer connected. If there is a way to do it with FORScan, don't hold your breathe for me to figure it out. That is above my paygrade. lol
Install a trailer brake light? Going to try today after adding feature to Forscan. Anyone get this work already?
Ford F-150 Lightning Remove full view not available and camera on signal? Screenshot_20251206_112219_Amazon Shopping
TrojanThor
Selections in steering revert. Eco Coach unselectable.
Ford F-150 Lightning Remove full view not available and camera on signal? 20251206_115630
Enabled rain sensing.
Some mods require both hardware and FORScan changes. Enabling the toggle may not be enough. I believe the 2025 Flash did not come standard with rain-sensing wipers. You might want to check if this actually works. If not, there is a thread where folks installed the sensor to enable the functionality.
astrand1
Alex
Studio truck driver
Problem with this is that truck will assume you have a trailer connected and most of the driver assistance aids will be unavailable like BC etc.
TrojanThor
Yea. I can disable the warning but BC unavailable, which is fine for my commute which is all under 55mph. Turn camera activation on Sync screen is a nice addition if BC and rear sensors aren't import for your route.
ssteven365
Scott
2025 F-150 Lightning Flash
So did this work for camera activation?
