New Pro Power Onboard toggle in iOS Ford app does not work
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
Like many, my Ford app got some kind of backend update and the Pro Power Onboard option showed up:
Ford F-150 Lightning New Pro Power Onboard toggle in iOS Ford app does not work IMG_0360
The only problem is that it doesn’t appear to do anything. I started the truck and turned on Pro Power from inside the truck and tried looking at this setting and all it shows is the following:
Ford F-150 Lightning New Pro Power Onboard toggle in iOS Ford app does not work IMG_0361
Anyone else’s with this toggle see it do anything? I know for now it is just informational, but it would be nice to see the info.
majorgearhead
majorgearhead
Summerville, SC
It's a monitor not a toggle, turn it on via your touch screen then you'll see values in the app.
Understand. Per my post I did just that. I turned on PPOB on the truck and opened this and found no values just like the screen shot above.
majorgearhead
majorgearhead
Summerville, SC
Pull down to refresh the app after you turn it on the big screen or however you refresh the app. I'm on Android.
Tried that and it did not work. Wondering if this is a bug in the iOS version for the Ford app.
Do you have any loads on the PPOB system?
IIRC, way back in V4.x.x of Ford Pass the load graphs would show levels, but I also recall that the data display was sporadic at times then, hence why they ditched it until the current revival, IMHO, they're still refining this feature and the tease to you IOS folks is frustrating I'm sure.
Hopefully they have it refined by the time my Android can see it.
ClevelandBeemer
Anyone with a XLT or Flash that has PPOB showing in their iOS app?
majorgearhead
majorgearhead
Summerville, SC
Update, today it actually showed data. It must have been some anomaly at the time I tested.
Kakaratto
Nate
2024 Ford F-150 Lightning Flash
‘24 Flash and I have it. I haven’t had the time to test it yet. Maybe this weekend I will…
ClevelandBeemer
Just showed up for me yesterday! 2025 job1 ER Flash with 9.6kW PPOB.
Ford F-150 Lightning New Pro Power Onboard toggle in iOS Ford app does not work IMG_8377
