bc1
- Oct 25, 2025
- McPherson, KS
- 2025 Ford f150 Lightning Flash
I don’t remember the code but it was listed as a checksum error. The HSM settings are a little different from the others. Every line in the as-built has a checksum, it’s the two dashes on the end that Forscan will calculate for you. In the HCM section the line 734-11-01 is a separate checksum for the whole module. I think I had missed the last 1 on the 734-03-02 line but I’m not certain.
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx--
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
HCM 734-01-02 xxxx x2xx xx-
HCM 734-03-02 xxxx xxx1 x1--
HCM 734-11-01 0735 89
And here are my codes when it was all done.
APIM 7D0-09-01 6117 4A28 FEC9
APIM 7D0-09-03 04C0 0004 07B2
IPMA 706-01-01 8E50 A059 AE94
SCCM 724-04-01 2844 0000 9C
IPC 720-01-01 0F8A 1064 D006
IPC 720-10-01 1B08 0023 007E
HCM 734-01-02 0001 0200 0041
HCM 734-03-02 111E 1801 0189
