GSM constant concern for many
I <3 My Lightning
Op..."Replicating the malfunction is easy, just shift into forward from reverse while still rolling back a little bit or, open the door while in gear with your hand on the shifter and hold a little pressure on it to stimulate you keeping it in gear at the same time."
I see the or, but are these separate issues? I ask because I occasionally will go from reverse to drive and haven't got a wrench yet. That being said, I do have an archived GSM code iirc.
@RLXXI , perhaps you have a TSB/CSP related shifter or discovered there are others beyond the TSB/CSP range or it is indeed broken and in need of a warranty replacement.
...because I am a 1 P driving phenom. I am constantly shifting between R and D and back without ever fully stoping. You should see me parking. People have asked me if it was a manual cause I am rocking and rolling like I'm floating/riding the clutch.
RLXXI
RLXXI
3rd rock
Automotive Technician
Perhaps, so long as I drive normally and not in a rush it's fine, only has 1895 miles on it and a 25 ym so it's still under warranty for quite a while yet.
Mine was worn out junk when I bought it. Young and broke, so I carried two long flat head screwdrivers with me just in case.
My Dad isn't around to ask anymore but I suspect the shift linkage was terrible from the factory. I know he carried a screw driver with him. I also know it was a Chevrolet but had a GMC dash installed new and the fenders started rusting before it left the lot.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
My Dad was an expert shifter of his column shift Chevy. My mom? Not so much.😂
Lost count how many times I had to unlock the column shifter on the old '53 Chevy for my mom. Pops finally fixed it by selling it for a '63 Impala automatic - mom was so peased !
rdr854
Northern Virginia
I had the module go bad on mine and it was replaced under warranty. While the stick feels cheap, I am not inclined to make the modification since I also have a 10 year 100K VSC that will take me to 2032 (I’ll never male it at the rate I am going since the truck only has 24K miles in 41 months). With respect to the rotary dial, we had that in our Ford Fusion and it worked well. I would have been happy if Ford had taken that route, but they did not.
RLXXI
RLXXI
3rd rock
I swear some days this place has bots posting.
Take your truck in for service to alleviate your concerns.
It doesn't bother me. :crackup:
RLXXI
RLXXI
3rd rock
kuzzin
Perry
texas
2023 Pro SR
23 Pro SR had GSM trouble from day one. The shifter would be in R or D and the instrument panel would show it in P. I was stranded a couple of times before the shifter would move to P on it’s own. Several trips for warranty and they couldn’t find the problem. Finally they replaced the 12v battery.
Problem persisted and then they replaced the GSM with the original part number. It failed again with the same issue stranding me again. This time it never moved to P. They replaced it again but with the new part number. No trouble since early October’25. The shifter feels and sounds better. Not so plastic slash cheap.
