Buying a Floor Jack
Rage866
Steven
Massachusetts
2025 Ford Lightning Flash
base jumping
I am buying a floor jack to change tires. Anyone know what the minimum lift height I will need?
I don't know what you need, but that subject has been discussed here. I recall someone noting Harbor Freight for a budget version.
SpaceEVDriver
Arizona
I have a 2.5-ton and a 4-ton Harbor Freight jack. I got the 4-ton when they had a 25% off coupon so it wasn’t much more than I was planning to spend to get a 3-ton and it gives me a little extra sense of capability. A 3-ton should be enough for corner lifting.
MountainAlive
Massachusetts, USA
RLXXI
3rd rock
Automotive Technician
Aluminum racing jack is what you want or do like I do and call AAA.
Randys Lightning
Randy
24 Lightning, 20, Road Glide, 23 Kaw H2 SX SE, 24 Yamaha FX HO Waverunner, +
Ret. US Army Nuclear Artillery and Ret. P&G Mechanical Engineer
I'm eying the 3 ton Harbor Freight Long-Reach Low-Profile Professional with Rapid Pump.
So many jacks don't even reach 20 inches (inadequate). This one is 24 1/4".
$189.99 right now through 1/19, via store stock, limited.
Al_V
Allen
Canton, Ohio
mr.Magoo
2022 Lariat ER, AMB
I reccommend the HF BADLAND 3 Ton Off-Road Jack.
I second this.
It lifts high enough where you don't need to use the extender / riser.
I only use mine twice a year and last time it compressed/lowered super fast (enough to set off the alarm) on the second wheel I swapped. Not sure if I was careful enough or if it "dries out" from sitting, but next time I'll make sure to exercise it once or twice before using it on the truck.
Other than that, very happy with it.
Al_V
Allen
Canton, Ohio
I second this.
The descent speed is regulated by the amount/speed that you turn the handle. If you crank it wide open, it will drop fast. If you want slow, just barely turn the handle, and adjust from there.
mr.Magoo
2022 Lariat ER, AMB
Thank you, though I've used enough hydraulic jacks in my days to have an OK understanding of their functionality.
I wasn't paying enough attention to know if it was me opening it too fast that particular time (it more or less "fell down", not just decended rapidly), or if the seals get a little bit dry from sitting 7-8 months without use, either way, I'll just "exerise" it once or twice before putting it under the truck and it should be a non-issue.
SpaceEVDriver
Arizona
MountainAlive
Massachusetts, USA
Do you have any concerns about horizontal stability with the air bags?
It was surprisingly stable. The air donut shapes are about 12in in diameter so it’s very beefy. I wouldn’t ever get under the truck with one of these but for lifting one wheel at a time to swap them for winter ones it’s worked great so far.
