HVAC - recirculate air button doesn't stay on
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Hey all
I have a 2024 Lightning Flash, and I have noticed for a while now that the recirculation button doesn't stay on for very long. Wondering if anyone else has seen this or has a resolution.
When I click into the climate screen, and then toggle the recirculation button, I hear the difference in the air flow as it starts to comply with what i told it to do....I exit the climate screen back to Android Auto, then I notice that I can smell that farm trailer that pulled in ahead of me, or that brush fire smoke that property is burning. So I click back into climate menu, and the recirculate button is off again. Like 30 seconds after I turned it on.
Has anyone else noticed something like this? Where the recirc button just won't stay on/toggled?
Thanks
F150guy
Garrett
2024 Lightning ER Lariat
I never use Auto. I mostly keep air flow to the driver floor.
I turn recirc off but I can tell it's still recirculating by the sound. Recirculating makes the fan sound a little more hollow. I have played with it and I think I have found if you lower the heat temp setting with the recirc still showing off, it will stop recirculating (again, by the sound).
I like to run HVAC manually and I can't stand that the truck still likes to "do me the favor" of still automatically controlling things.
Yes, other people have seen this, search in the forums if you like but no workaround.
irunalot
2025 F150 Lightning
Many (many) years ago, I was an automotive engineer in Climate Control. When it was warm out and the AC compressor was running, recirc would stay on as long as the customer wanted recirc. However, if the compressor was off, regardless of temp, the recirc would automatically revert back to “outside air” after a minute or two to prevent internal fogging of the windows, particularly the windshield. Not sure if that’s your situation; just wanted to let you know there’s a safety reason for turning off recirc automatically, under certain conditions.
If, however, your compressor was running and recirc turned off, I can only speculate that it’s to save battery. Recirc mode pushes more air and that means more blower work and higher amperage, therefore more power consumption 🫤
Like @Maquis said, do not use auto if you want recirc. I have had good luck with this on road trips that pass by dairy farms.
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
@Ford Motor Company and it would be awesome if we could get the recirc button up on the main screen instead of having to get into the climate details to turn it on. Maybe replace the superfluous max def. button on the screen
Ford Motor Company
Official Ford Account
F-150 Lightning
Noted!
DavidYo
Michael
2023 F150 Lightning XLT ER
Recirc will stay on if you do not use “Auto” and direct air to the dash vents only.
This worked great for me thank you. It was such a pain having to press that button every three minutes.
bc1
McPherson, KS
It would be nice to see that in the next software update. Even the Japanese figured out they should leave manual hvac controls below their screens for quick and easy access while driving instead of the zillionth of a second allowed on the sync screen to change something which all that does is force a driver to repeatedly divert his attention away from the road multiple times in order to make one little change. It shuts down before I can make a change most of the time.
Just give us more time. It takes time to look down to find the button to push and then more time to turn the dial, etc. With more time a driver can glance back and forth to the road while making changes on the sync screen doing it just one time.
DavidYo
Michael
I like XLT setup better since it has buttons and knobs. I don’t have to look at all to use them and can make changes be feel. The software in Ford vehicles is so bad that I am happy to have as many buttons as possible.
PJnc284
Garner, NC
It's amazing that in all their infinite wisdom, someone thought it was necessary to give us a hard and soft button for max defrost with the big screen.
