Chaldaean
- Oct 23, 2025
- New England
- 2024 F150 Lightning Platinum
I bought a used 2024 Platinum with 10,000 miles in October and have driven it around 2,000 miles.
Like the title says, how can I get into the truck if the physical lock is broken and the 12V battery is dead?
Backstory:
(1) January 11th: Installed brand new DieHard H3-XEV battery as I had gotten the "Vehicle in Battery Saver Mode" message and this replacement would rule out a bad battery.
(2) January 24th - 28th: Went away on four day trip and left the truck plugged in at home.
(3) January 24th: The "Vehicle in Battery Saver Mode" message popped up which also said "Start your vehicle manually to access remote commands"
(4) January 25th: The App notified me that the frunk open and there was an "Opened hood triggered alarm". I reviewed video footage from a home surveillance camera and the there were definitely no intruders. Listening the audio in the surveillance footage, there was a "click" like the frunk was unlatching and then the lights on the truck started flashing (there was no audible alarm).
(5) January 27th: The App notified me that there was an "Alarm Triggered" and said "The F-150 security system has detected vehicle intrusion and triggered the alarm". There was no audible alarm. The App also reported a "Charging Error" that said "Pleas heck your vehicle or charge station for details".
(6) January 29th: Returned home from the trip and found the truck to be completely bricked/unresponsive. I could not unlock the doors from the app, the keyfob or the keypad. For some reason, the physical key does not work and the lock is broken (the key can turn 360 degrees in the lock). So, I can't open the door to use the manual frunk release in order to charge the 12V battery. I had a Ford Roadside tech onsite today and he couldn't get the truck unlocked (he used a wedge, an airbag door frame spreader and a pole/hook, but that was fruitless as all interior buttons are unresponsive due to the dead 12V battery). He also tried to use a SlimJim to pop the lock, but was unsuccessful. I can have it towed to the dealer, but since the tow truck driver can't get in the cab to put the put the truck in neutral, the truck would have to be dragged without the wheels spinning, which is not ideal.
I'd really like to get the door unlocked to avoid towing.
Backstory:
