dww
- First Name
- David
- Dec 10, 2023
- San Antonio, TX
- F150L, Tesla 3P, YP
Wow. And that’s after you got the 12v back up?Here you go!
That video was taken before getting the 12V back up, but the behavior remains the same now that the LVB is fully charged. Voltage doesn't seem to have any affect on the lock behavior.Wow. And that’s after you got the 12v back up?
Holy Sh*T, just cuz a dead battery and broken door lock . . . .All, thank you very much for your help with this. I was able to unlock the truck by:
(1) Removing the wheel/tire
(2) Removing the wheel well liner
(3) Locating the underside of the positive jump terminal (it's not possible to access the top of this terminal as there is a red plastic cover on it and there isn't enough room to remove/hinge the cover out of the way) and making contact with a long metal probe. I used a random piece of round stock and insulated most of it with electrical tape (a long screwdriver would probably work).
(4) Locating some sort of chassis ground - I used a bolt nearby the standard negative jump location (see "In Lieu Of" bolt in the images below), but there's probably a much easier ground somewhere. I had a SlimJim that I had tried to use to unlock the door that I used as a conductor/probe.
(5) Applying external 12VDC to the jump terminals (I used another AGM battery, but a booster pack or a wall charger would work, too).
(6) When the vehicle powers up (which is pretty much instantly), hit the "door unlock" button on the key fob
(7) Remove the external 12VDC power
(8) Use the manual frunk release cable in the driver's foot area to open the frunk
(9) Charge the truck's 12V battery and cross your fingers that this situation never arises again
Another thing to watch out for, the spinning key in the lock!Holy Sh*T, just cuz a dead battery and broken door lock . . . .![]()
Not a pro, but I suspect the lock rod isn't attached in the door.Here you go!
Good Idea, I bought my truck in Dec of 23, and only have 7k on it, Need to pull my meter out & check my batteryAnother thing to watch out for, the spinning key in the lock!
Maybe they should have put a key lock on the hood and allow it to be manually opened from the outside once unlocked if they wanted to make it into a front truck and have the 12v battery access in there...
On the Prius while the battery is in the back hatch, there are jump terminals under the hood...but of course there is a latch inside the vehicle that should be pulled to open the hood - but you can use a long screw driver to unlatch it from the outside through the front grille if you can't get the doors open.
Another reason I am glad I put an SAE cord accessible from the outside on my Lightning - while I would not put a 'jump' level current on it, with enough time and patience, I could trickle it back to a sufficient level to open the frunk with 12v battery power (I hope).
Yes, once the 3yr warranty is up, the battery replacement cost is on the owner.Good Idea, I bought my truck in Dec of 23, and only have 7k on it, Need to pull my meter out & check my battery
I just tried the lock from the 2022 LER in my 2023 LER door lock & it did not turn. The 2023 FOB key did turn the lock as expected.Can someone try a known incorrect key on their lock and see what it does?
