Pacific.NW
- First Name
- Christian
- Apr 17, 2025
- Vancouver, Canada
- 2022 Lightning Lariat ER
I was doing “truck things” with my truck yesterday and rented a trailer to haul small landscaping equipment. Everything connected properly and the light check was good. I went out for a walk in the evening (the trailer had been left connected) and noticed the tail lights of the trailer would blink a very dim but noticeable pulse every 2s or so.
I typically pull a small travel trailer using the old school 4-pin connector and have never noticed this before. I figured either this was a safety thing to make the trailer more visible (even if the blink was dim), or there is some weird fault in the electrical causing a blip on the lines.
It was at this time I discovered another fin fact about the Lightning and a trailer… if you unplug the trailer electrical while your vehicle is locked, you will set off the alarm (if it’s enabled)!
So I’m standing there trying to fumble with my app to get the vehicle to stop honking and because I’m still connected to my home’s wifi, but not close enough to get a decent signal, the app is showing blank boxes where the buttons should be. It was a bit of a comedy of errors but managed to get it to stop.
Anyone else notice the blinking or alarm quirk?
