CoolViper777
- First Name
- George
- Feb 6, 2026
- Pittsburgh
- 2019 Ford Expedition & potential F150 Lightning owner
- Occupation
- Software Engineer
My Total generation was:
Oct 2025 - 347.2 kWh (My system wasn't fully function most of the month, only 1/3rd panels working)
Nov 2025 - 404.2 kWh (The malfunction panels kept going partly into Nov as well). The solar installers had to take apart the system, and verify the plugged everything correctly and in phase.
Dec 2025 - 228.7 kWh
Jan 2026 - 221.3 kWh
Feb 2026 - 562.6 kWh
Mar 2026 - 268 kWh - so far
It does seem the estimates are a bit high. That's why I am adding another 4.4kW of panels, can never have too much solar power.
I hope I am wrong but seems like the production estimates might be high for Pittsburgh. Similar latitude to me in the NY Finder Lakes, similar weather too. Mine are ground mounted so perfect south direction and optimal pitch, roof determines these values and likely less than optimal.
This Dec I did 571 kWh, same as they estimate for you and I clean , off the snow if the forecast is for a day of sun, 6 years of data the Dec range is 571-770 kWh. Hope they are accurate, I certainly know you can't have more cloudily weather than I do.
