- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
So...in some years it was a no no, and in others it was OK?Maybe Ford's concern with leaving PPOB on with the truck off is some kid fooling around with the outlets in the truck bed and frying themselves on the 240V outlet? So, it just seemed safer from a liability perspective to have PPOB off when the truck is off (and presumably might be unattended).
That does not compute.
Seems like on my truck, if I had the shut down time off when I turn my truck off, it stays that way when I turn my truck on the next time, without any FORscan tweak needed.They could easily fix it in a software update by removing that silly low power / inactivity shutdown, yes. No there is no known fix in Forscan. But no a dealer can't do anything; the software gods would have to do it.
I just leave the truck "on" with the main shutdown timer disabled (there *is* a Forscan tweak to have that one permanently disabled if so desired) if I have my cooler running. I usually have the dog in the truck so I need it "on" for the climate control anyway.
The PPOB defaults to on as well if I had it on before.
