What is the Trick? To leaving the Pro Power ON?
K6CCC
Glendora, Calif.
I'll bet that every module that is alive when the truck is on, is alive when the truck is "off" with ppob on.
Off hand, that would surprise me.
Should be moderately easy to check. CarScanner and an OBD2 reader should be able to measure power consumption. Only problem with that is that just having the OBD2 reader plugged in does result in more stuff powered on.
Kansan
Wayne
2024 Flash
Civil Engineer
I put it through a day long (about 10 hours) test last weekend during the big storm that blew through the Midwest. PPOB was on and powering my entire house. Truck off. I had my OBD2 scanner connected. I was able to connect and read most parameters the entire time, but it would not read/show any of the "displayed" parameters such as SOC Displayed. It also would not read/show pack voltage, Battery Max Allowable Temp, or Battery Variation in Voltage Measurement. The SOC Displayed was basically stuck at the value it read when I turned the ignition off. The next day when I drove the truck to work, it started at the previously, and incorrectly high, SOC Displayed. Over the first couple miles SOC Displayed adjusted gradually to a stable reading in line with (and appropriately higher than) the HvbSoc "actual."
During the test I really only checked one other item. I was hoping for the Wifi to remain energized during PPOB on while the truck is off. I'm paying $10 a month to have the 4G wifi hotspot to be active in my truck. With Truck Off, PPOB On, Wifi was deenergized.
Kansan
Wayne
2024 Flash
Civil Engineer
Interesting..so keeping the 12v battery from discharging isn't the reason for the threshold, at least in your Flash.
I just posted a minute ago about powering my house for 10+ hours last weekend during the big storm. For all but the first 20 minutes I had PPOB On, Truck Off. At the end of the test, before shutting down, the low voltage system was floating at 13.9v, it showed my 12V battery at 100% SOC, and 12v battery current at 0.0A. So, during the test it had fully topped off my 12v battery and all 12v power was coming from the DC-DC converter.
I usually stretch out my charging sessions to last 6 hours, to match my super-off-peak rate period. I have a bluetooth monitor on my 12V that logs voltage at the 12v battery. During my charging sessions I regularly see 14v during the first hour or two (I assume this is to support a higher charge rate of the 12v battery) followed by 13.5v until the end of the charging session. At the end of the 6 hour charging sessions the 12v battery always shows 12.98v.
When I started my test last weekend, with PPOB On and the Truck On the 12v system was at 13.5v (the low rate charge voltage I see during HVB charging) - I did this for about 20 minutes so I could compare what the truck was showing as watts per leg to the Fordpass app readings. When I turned the truck off the voltage jumped to 14v and stayed there for the entire 10+ hour event.
Interesting thanks.
I always wondered if the DC-DC inverter would be on keeping the 12v battery charged when the PPOB was active and the truck was off - no way to check on my 2023 that doesn't have the PPOB on when truck off feature, but now I know.
Yes, I knew the 12v battery would be getting charged during a L2 HVB charging session, that had been documented before. And the longer the charge session the better the 12v battery gets charged - may actually get topped off to 100%.
One thing I still wonder, when the truck is plugged in to the L2 EVSE, warming the HVB but not charging the HVB, is the DC-DC converter active and is it charging the 12v battery?
That now seems possible based on your results.
bc1
McPherson, KS
This is my biggest complaint.. heck with coolers, etc… but clearly Ford hates dogs. They don’t care if Spot is kept toasty in the winter and cool in the summer. Very disappointed in Ford.
I see this more as Ford not wanting to deal with lawsuits and enable idiots to leave their babies in the truck while they spend all day at work or all night at the bar in hot or freezing weather.
djryan13
DJ
Ford Lightning, Tesla MS
I was thinking same thing but why can other manufacturers get away with it? Or does Ford not trust their tech?
Kansan
Wayne
2024 Flash
Civil Engineer
I don't use departure times often, because my truck is in the garage. But I did use a departure time yesterday and the truck was plugged in and had completed charging the HVB. The voltage at the 12V battery went to 14.3V during the warm up for the departure time.
K6CCC
Glendora, Calif.
Well I believe folks here have shown the DC-DC converter is live. The AC inverters are cooled from the liquid cooling loop, so the pump is involved. The becm needs to be active.
If we're talking about the load on the PPOB at such a low load that tricks are required to keep it running, cooling it is NOT going to be much of an issue!
I can tell you that a half hour or so ago I left my truck off with PPOB on with about a 150 watt load. It was almost 90 outside and the heat pump was NOT running.
ryun
Earth
Forgot to mention but for anybody looking into just leaving the truck on you've got to turn off the auto shut off timer as well. Otherwise you'll lose PPO after 30 mins.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
Have a 23. I camp all the time. It’s pretty easy to remember.
Leave truck on. Turn auto shutoff timer off. Turn off HVAC. Switch lights to off. Done.
Works great and never shuts off unless I hit my PPO limit that I set to make sure we have range to get back home after camping.
Really not a big deal.
jobofly79
Joe
2024 Ford Lightning Flash 312A
Someone with the "Pro Power on while truck off" option should do a test. Charge to 90% before each case. Test for at least 24h to get enough significant figures on the battery discharge. Ideally test for long enough to get 10% HVB discharge. Keep vehicle in garage. Turn HVAC off, headlights off, put screen on calm (push dial in and turn). The heater on timer method seems to be 1s on, 300s off to defeat the 6 min timeout.
Case 1) Truck ON, Power Power OFF
This is the baseline power draw of the truck's systems
Case 2) Truck ON, Pro Power ON - either no load or the heater on a timer
2-1 is the power of keeping the inverter's active
Case 3) Truck OFF, Pro power ON with "Keep pro power on while truck off" with the heater on a timer
3-2 is the power saving benefit of this feature
I don't have this "keep pro power on while truck off" feature on my '23.
I just did this over the weekend 3 days, 2 nights. I was camping and using pro power on board. I used the PPO to run my heated blanket in my roof top tent each night. I also used it to power my electric kettle, electric cooler and nespresso machine. I arrived at camp with 65% SOC and left this morning at 56% SOC. It got down in to the mid 30’s. I did get in my truck Saturday morning and out the heat on to get warmed up. Overall I was happy with the amount of power I used. However, constantly worrying about the PPO going out overnight sucks. Ford really needs to fix the minimum draw issue.
bc1
McPherson, KS
I do this on a daily basis as I use PPOB to power my dash cams while I'm working as a sort of sentry feature. After 8 hours of only powering twin dash cams, Front/rear with built in DVR, to include using the timer/heater keeping PPOB alive, the most I've seen is ~3% of HVB usage.
[/QUOTE]
Do we have an Amazon source for the timers being used? Also is there some other electronic device on the market that would pull 100-300 watts that would be safer than a heater or light bulb?
I like the idea of powering the dash cams for theft purposes such as with ppob but I wouldn't want to leave the truck on all night at a motel with a lit dash and calm screen even if I covered them. Best choice is just to take the chances of not running down the 12v battery even though it doesn't pull that much power. I'm still looking for a 360 degree dashcam system that isn't that expensive. Adding a recorder to the trucks cameras would be nice if they could be used.
bc1
McPherson, KS
This is the timer I use the heater is perfectly safe as it doesn't stay on long enough to get hot.
Thanks. Problem is my wife won't think a heater is safe. I see it retains it memory without power. Don't know how long though if I use one intermittently just for travel.
Jamchampnate
Nate
Utah
[/QUOTE]
What’s the concern with the car being left on if it’s locked and no key or phone inside? If someone tries to break in and tried to drive off, it ain’t going anywhere without a key. It’ll shutoff.
