And the wheels/tires makeupAlso note that per Ford, the platinum can tow 8,500lbs while the lariat max tow is rated for 10,000lbs. Basically because of the extra curb weight of the platinum.
Answering questions on an enthusiast forum with AI is pretty meta considering the algorithm was almost certainly trained on data from the forum.FWIW...
AI says about 2023 trim variations:
Wheel size:
Breakdown by Trim:
Pro & XLT (Standard Range): Equipped with 18-inch machined/alloy wheels (paired with 275/65R18 tires).
XLT (Extended Range) & Lariat: Standardizes up to 20-inch alloy wheels (paired with 275/60R20 tires)
Platinum: Features the largest 22-inch bright machined/alloy wheels (paired with 275/50R22 tires)
Impact on the Vehicle:
Efficiency & Range: The larger 22-inch wheels on the Platinum are heavier and feature a wider, less aerodynamic profile compared to the 18-inch and 20-inch setups. This contributes to the Platinum's slightly lower EPA-estimated range (300 miles) compared to extended-range XLT and Lariat models (320 miles)
Ride Quality: The 18-inch and 20-inch wheels leave more room for tire sidewall, which provides better cushioning and forgiveness over harsh, bumpy roads. The 22-inch wheels, while visually striking, offer a stiffer, firmer ride.
Weight Breakdown by Trim:
Pro & XLT (Standard Range): ~6,015 lbs
XLT (Extended Range): ~6,361 lbs
Lariat (Standard Range): ~6,170 lbs
Lariat & Platinum (Extended Range): ~6,590 to 6,893 lbs
Range Differences by Trim:
Pro: Standard-Range battery is standard. Range: 240 miles
XLT: Available with Standard-Range (240 miles) or Extended-Range (320 miles).
LARIAT: Available with Standard-Range (240 miles) or Extended-Range (320 miles)
Platinum: Extended-Range battery is standard. Range: 300 miles
Key Weight Factors:
The Battery: The larger Extended Range battery pack alone weighs roughly 1,800 lbs, adding about 300 to 400 lbs to the truck's total weight compared to the Standard Range
Trim Add-ons: Higher trims like the Lariat and Platinum include luxury features (power tailgates, upgraded audio, premium interiors, panoramic sunroof) which slightly increase curb weight.
Towing/Payload Trade-off: While the heavier Extended Range trims (like the Platinum) have higher towing capacities, all Lightnings must be mindful of their payload limits, which max out at around 2,235 lbs for the Pro and 1,800 lbs for the Extended Range trims
I recently aired down to about 38 psi to improve the ride on the crappy roads in my town. Well worth the small loss in range to me.Make sure you are running the Platinum at 44-45 PSI. I think it’s higher than Lariat. At 45 psi I easily get 2.0+ kWh/mi at 70-75 mph.
