- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Hmmm...Update here. So I eventually took the truck in to a local dealer because I couldn't ever get it to DC fast charge again. They told me that they replaced the "charging harness". It was covered under warranty which is good. Attached is the invoice/service notes. Got the truck back and was able to successfully fast charge. Once at a Tesla Supercharger and once at an EVGo location.
Fast forward to today. Wanted to test it again and both (Tesla and EVGo) failed. The truck told me it was a Vehicle Charging Fault and that I should service the vehicle soon. It was over a 100 degrees and the battery temp gauge was showing slightly over the midpoint. Planning on taking the truck back in tomorrow morning to see if they can figure it out. If any of this makes sense to anyone and has advise, I would appreciate it. Love the truck and its worked great for me for about a year and half. But I need a vehicle that I can reliably take on road trips from time to time. Even if it is hot outside.
The charge port and cable are the usual suspects.
Next on my list would be the on-board L2 AC-DC and DC-DC charger circuitry if it were an L2 issue.
But since it is DC charging...I was thinking something in the communication between the DC charger and the truck is failing and there is a stuck fault code?
So I was going to suggest doing the 12v disconnect to clear any fault codes that might persist, but if they were able to charge after the parts replacement, I don't know...
You could try it though: "Remove the negative terminal from the 12v battery, leave off for 5 minutes, reattach, you may need to manually close the Frunk and test first opening with the cabin button near the steering wheel."
Another couple of owners had a DC fast charging issue, and it turned out to be an actuator that locks the DC connector (is that part of the charge port your dealership replaced?) see this thread
https://www.f150lightningforum.com/forum/threads/dc-charging-fault-151-miles-away-from-home.16384/
and this one:
https://www.f150lightningforum.com/...rger-not-connecting-post-27-resolution.16549/
Here's an excerpt from the first thread:
"Got the truck back today. The fault was with the actuator to hold in the connector during DCFC.... It ended up being the actuator that “locks” the DC connector. Back to normal...."
And from the second thread:
"Resolution: I got my truck back yesterday from the Ford Dealership - yes, they confirmed this is a known issue with the Lightnings - they replaced my charge port actuator, and now I can DC fast charge at my local EA charger without a problem..."
The technical service bulletin from the first thread shows the replacement of the actuator on page 6.
There were two PDFs associated with those thread the TSB aand another, and I attached them.
