PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX!
Ford Motor Company
Official Ford Account
F-150 Lightning
Ford Motor Company
F-150 Lightning
So are you saying something else was delivered and the release notes were wrong? If so, what was delivered, i.e. what are the real release notes?
Let me ask the team and see what they come back with.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Do you have it set to fold the mirrors on lock? Might turn that on, if not and see if it stops honking.
Yes, the mirrors fold on lock. Mirror fold has nothing to do with the honk. Since WAL was activated it honks after closing the tailgate or frunk, too.
The missing control looks like this (from my Mach E):
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_2264
jetfixr1
Anthony
Atlanta
First of all, thank you to this forum for helping us escalate internally.
Some F-150 Lightning customers (including folks in this thread) recently received a software update with release notes stating they received the Walk-Away Lock Feature. Unfortunately, the release notes were sent in error and the feature was not delivered. While we are working to deliver the Walk-Away Lock feature on equipped vehicles with Keyless Entry, the feature is not available at this time.
The team apologizes for any inconvenience and confusion this has caused. We look forward to sharing an update when it is ready for you to use.
Holy f*** - This is the type of engagement we’ve been looking for! Thanks Brian!!
02Reaper
GA
2022 Lightning XLT ER
Thank you for the update Brian. It’s nice to see a representative engaging in a helpful way.
ThunderSnoww
Kevin
Detroit, MI
2023 F-150 Lightning - Lariat ER - Antimatter Blue - BC 1.4 (on 08/15/25)
I got this update on Monday. I have no toggles and it does not activate. 2023 Lariat ER. I’m still on standard Bluecruise with no lane change.
Same update situation as my '23 Lariat ER (built 9/2023). Got this SYNC-25.2.1.6.5 "update" Monday evening with such toggles as outlined in the release notes. The only other updates I've had this year are DDM 25.12.0 (window functionality) on April 10 and ECG-24.2.5.7 (gateway module) on February 28. Still no BC 1.4 or ECG-25.2.5.7.1 (LVB performance). Having those would be substantially more beneficial.
ThunderSnoww
Kevin
Detroit, MI
You still another update for the BCM in order for it work.
To (eventually) activate WAL (post PU-Sync-25.2.1.6.5), do I need BCM-24.5.1, or is the there a different BCM update I still don't have?
rugedraw
Javier
Miami
Auto Sales
Pretty sure that's the BCM update.
Deleted member 15277
Guest
No, this is a two-part update. You still another update for the BCM in order for it work. The release notes should have some kind of disclaimer saying something about this, but it does not. Either way, you got newer Sync software that most likely has other improvements built into it. Eventually, the update you need for WAL to actually work will come in.
Yeah, that's what my limited research shows - sad that its not in the release notes, or worse, why push this release before the other dependency is met. Makes no sense and is confusing for the end user. I was almost inclined to open a service ticket to "fix" the broken WAL -what a waste of a dealer visit if ppl actually do as I would think.
rugedraw
Javier
Miami
Auto Sales
Well, if the dealer would do the BCM update, it would fix the issue of WAL not working. As stated by not AI Brian from Ford, the release notes are erroneous. Seems like that verbiage should not have been in there at all, or something else should be in there to let people know about it.
I can only imagine the confusion of all the owners NOT on the forums who have to try and figure this out on their own or with their dealer who is just as clueless as to what is going on as they are.
‘22 Lariat. SW is downloading. I’ve got an updated BCM and added controls via Forscan, so it all works. It’ll be interesting to see what this breaks or if all works or if I have to get Forscan out again.
rugedraw
Javier
Miami
Auto Sales
I would start dusting off your FORScan cable. :ROFLMAO:
digitaldad
ABQ
2023 Lariat ER MaxTow
The Lightning sub-reddit has these posts of confusion/asking questions as well.
Don't know how, but it all survived. New Sync version 25094 (which I'd been really worried about with the news a month or so back), WAL settings still present and set correctly and WAL works like a champ still.
Maybe time to buy a lottery ticket. Oh wait - I did on the way home.
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_9120
rugedraw
Javier
Miami
Auto Sales
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! hallelujah-85-hallelujah-two-spies
