Caliber357x
Just got this update too - now to wait for the BCM update.
Yes, it seems like this OTA is enabling the config for the buttons for WAL to show on some trucks and not for others. I've seen stuff like this happen with other OTA's in the years I've been following this. The BCM is update is mandatory for WAL to work.....the buttons you get with this update are secondary.I have the BCM update (thus WAL is enabled), but I can't turn it off. I got this update, but I still can't turn it off. Seems like Ford missed something in this release ... like the actual change described? (yes I know it can be done via forscan)
No. Mine didn’t start honking the horn when it locks. I have those functions turned off in the settings so it didn’t honk before when locking it manually or leaving the truck running and taking the key with me.When you say it works, does it honk every time you walk away and it locks?
No, and it doesn’t actually workWhen you say it works, does it honk every time you walk away and it locks?
First of all, thank you to this forum for helping us escalate internally.No, and it doesn’t actually workthought it did, but just tried it 2 more times & came back to an unlocked truck
Some F-150 Lightning customers (including folks in this thread) recently received a software update with release notes stating they received the Walk-Away Lock Feature. Unfortunately, the release notes were sent in error and the feature was not delivered. While we are working to deliver the Walk-Away Lock feature on equipped vehicles with Keyless Entry, the feature is not available at this time.
The team apologizes for any inconvenience and confusion this has caused. We look forward to sharing an update when it is ready for you to use.
Thanks Brian - it's probably worth noting that other members received a prior update which turned the walk-away-lock feature on, with no way to disable it, and the release notes also indicated that this situation would be fixed in this update (which it did not).First of all, thank you to this forum for helping us escalate internally.
So are you saying something else was delivered and the release notes were wrong? If so, what was delivered, i.e. what are the real release notes?Some F-150 Lightning customers (including folks in this thread) recently received a software update with release notes stating they received the Walk-Away Lock Feature. Unfortunately, the release notes were sent in error and the feature was not delivered.
I would assume it's like what the mach e received with this same update.So are you saying something else was delivered and the release notes were wrong? If so, what was delivered, i.e. what are the real release notes?
Nope. There is one setting for horn honks that I have had off since the truck was delivered.No. Mine didn’t start honking the horn when it locks. I have those functions turned off in the settings so it didn’t honk before when locking it manually or leaving the truck running and taking the key with me.
You should check those settings in your truck.
Thanks Brian. Glad to have you back!First of all, thank you to this forum for helping us escalate internally.
?My truck only honks on walkaway.
